Author Topic: Longmont/Boulder CO area riders....need help with my Mille 😞  (Read 5571 times)
BoulderBreck
« on: February 21, 2016, 01:32:22 PM »
Mechanically disinclined owner of '89 Mille GT needs help. Bike has been on tender since October (foot surgery, then old man winter).  Gas stabilized. New spark plugs. Bike turning over strong, not starting. Guessing fuel delivery issue...?  Need advice or more so someone willing to help out in exchange for..?
Days have been too nice and frustrated.
Rick
Re: Longmont/Boulder CO area riders....need help with my Mille 😞
« Reply #1 on: February 21, 2016, 01:48:55 PM »
I'd pull a plug lead, attach a plug and make sure I had spark.  Is it possible the leds weren't attached when you changed plugs?
Hopefully you have compression.
BoulderBreck
« Reply #2 on: February 21, 2016, 02:41:03 PM »
Yeah, pulled the plugs and tested, no spark on the new plugs. Leads connected.
« Reply #3 on: February 21, 2016, 02:44:16 PM »
Possibility that when changing plugs, wires came loose from coils?
Here, someone else had issues:
http://advrider.com/index.php?threads/moto-guzzi-mille-gt-ignition-problem.798215/
Ignition trigger in distributor?
« Last Edit: February 21, 2016, 02:47:50 PM by Norge Pilot »
« Reply #4 on: February 21, 2016, 03:42:54 PM »
I think MotoGeezer lives in Longmont
Offline Two Checks
« Reply #5 on: February 21, 2016, 03:58:12 PM »
Moto(s)plat ignition gone Tango Uniform?
Not a matter of if, but when it happens. If the case, replace with points and don't look back.
1987 1000 SPII "Il Duce' II"
« Reply #6 on: February 22, 2016, 09:53:34 AM »
someone said that most carburetor problems were ignition related.   :huh:
Online redrider90
« Reply #7 on: February 22, 2016, 11:17:02 AM »
Well there is your problem for sure.
89 came with points but you could have an after market electronic ignition Do you know if you have points or an aftermarket electronic ignition?  That both sides are dead says with your wiring harness is not connected properly or you have an ECU box for an electronic ignition that is dead. If you have points then it's simple. Check coils, check points and see if they are clean and set and check wiring harness. Also check condensers. My guess is you have a dead ECU box but stock Guzzi coils suck and will die. So they need to be checked with an ohm meter but if you are mechanically challenged you might not have an ohm meter.
Red 90 Mille GT
Online redrider90
« Reply #8 on: February 22, 2016, 11:19:15 AM »
89 mille had points. Motoplat was 90.
Red 90 Mille GT
redrider
« Reply #9 on: February 22, 2016, 11:20:18 AM »
Not being snarky-what position is the kill switch in?
« Reply #10 on: February 22, 2016, 11:21:53 AM »
 Yeah , always start there .
« Reply #11 on: February 22, 2016, 04:36:44 PM »
More than one guy has cranked one with the kill switch on. Not that I would ever have done that, of course. :smiley:
redrider
« Reply #12 on: February 22, 2016, 04:44:15 PM »
I, of course, was BORN with this knowledge nugget. I have NEVER done such a thing. :grin:
Offline Two Checks
« Reply #13 on: February 22, 2016, 05:02:38 PM »
I knew 90 had Motosplat  (see tag line) but it seems I read somewhere (my pornographic memory is failing) the Motosplat was phased in late 89. Then again, I could be entirely crazy.
