Author Topic: Di-electric grease on new electrical connections?  (Read 11119 times)
Offline MGPilot
« on: March 05, 2016, 07:22:35 AM »
I've worked on a lot of old cars over the years where corrosion in electrical connections can be a real issue.
I have two new motorcycles.
While the connections are new and clean, would it make sense to put a light coating of di-electric grease on many of the connections to keep moisture away from the surfaces?  Or would the grease itself dry up and create issues over time?
2014 Morgan Three Wheeler
Re: Di-electric grease on new electrical connections?
« Reply #1 on: March 05, 2016, 07:24:39 AM »
 Chuckie will be along shortly to explain why you don't want to do that  :laugh:
Offline thepittsburghguzzi
« Reply #2 on: March 05, 2016, 07:27:23 AM »
I'm curious to hear what Chuckie has to say. I was considering doing this to my Classic to prevent corrosion. Moisture and grime could eventually sneak into the connections if there isn't a grease buffer there, so I'm wondering where the harm is.  :popcorn:
2012 V7 Classic - Scarlet
1979 KZ750 Twin - Copper
-Paul
Offline chuck peterson
« Reply #3 on: March 05, 2016, 07:30:48 AM »
Apparently, from what I've read here...diaelectric off gasses something harmful...DeOxit does better
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
« Reply #4 on: March 05, 2016, 07:36:04 AM »
 When Chuckie gets done , Wayne Orwig and Kiwi Roy will step in and finish the job  :evil: C'mon you guys in EST , wake up , get to work here  :laugh:
Offline Dilliw
« Reply #5 on: March 05, 2016, 07:36:24 AM »
This will be fun.  For the record I have seen Wayne use the stuff.   :evil:
George Westbury
Austin, TX
Offline Zoom Zoom
« Reply #6 on: March 05, 2016, 07:36:35 AM »
Look for something called "terminal grease", not dielectric grease. Dielectric will eventually insulate the connector itself, rather than protect it.
Wayne Orwig explains it much better, but that is the jist of it.
John Henry
« Reply #7 on: March 05, 2016, 07:36:51 AM »
« Reply #8 on: March 05, 2016, 08:18:23 AM »
 :Beating_A_Dead_Hors e_by_liviu
Offline jetmechmarty
« Reply #9 on: March 05, 2016, 08:19:48 AM »
I have a couple of 35+ year old Japanese motorcycles that I ride.  They were build using inexpensive unplated wiring and cheap connectors.  I never put dielectric grease on any of it with the exception of the spark plug boot.  From time to time I have taken everything apart and cleaned it with proper solvent.
I took a trip over 2,000 miles last spring on my 1980 Yamaha.  I attended a rally.  One of the riders had just reterminated the wires and replaced the connector to his alternator.  He did this just before his ride down from Canada.  At the rally in New York, his battery quit charging due to no input from the alternator.  I had a look at it for him and found the connector was overheated and melting.  It was also full of dielectric grease.  Cleaning up that mess on the side of the road was no easy task.  That stuff doesn't like to come off with common solvents found at the parts store down the street.  It's been said on here before.  Dielectric grease is an insulator.
Dielectric grease makes a great o'ring lube!
Marty (in Mississippi)
No Guzzi right now
Offline sign216
« Reply #10 on: March 05, 2016, 08:49:35 AM »
For low voltage connections (i.e. not the spark plug) you want electrically conductive grease, like Ox-gard, Noalox, No-ox-id, etc.  Found in hardware stores wiring sections, used on aluminum to copper connections in house wiring, where the dissimilar metals accelerate corrosion.
This stuff conducts electricity instead of insulating it, and still protects the joint from corrosion.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
« Reply #11 on: March 05, 2016, 08:54:02 AM »
I often use a little general purpose grease on connections that might be exposed to the weather, and have never had any problems with doing that.  I always put some on tail and turn signal bulb bases, and it works well for keeping them from corroding over the years, even on boat trailers.
I've used Penetrox on outdoor electrical connections in commercial applications.  Burndy makes several type of Penetrox, for use on different metals and combinations of metals, so you'd need to get one suitable for copper-copper connections for most motorcycle connectors.  Penetrox E is made for copper-copper.  Other types are for things like joining aluminum wiring to copper terminals.
Edit:  Typed in parallel to sign216's similar post.
« Last Edit: March 05, 2016, 08:54:50 AM by Triple Jim »
« Reply #12 on: March 05, 2016, 08:55:54 AM »
I spread that $hit on everything. :rolleyes:
Here are my thoughts:
http://hogmountain.homenet.org/Dielectric_grease.htm
If you are at any rallies, let us know so we don't park too close. :boozing:
« Last Edit: March 05, 2016, 08:58:09 AM by OMG »
Offline Dilliw
« Reply #13 on: March 05, 2016, 09:03:47 AM »
Ahh, he woke up!  And that's exactly where he used the grease- on the spark plug boot.
https://www.youtube.com/watch?v=-542IYGBbpg
George Westbury
Austin, TX
Offline MAC
« Reply #14 on: March 05, 2016, 10:17:47 AM »
I just purchased a Dobeck controller for my Norge.Dobeck says do not put dielectric grease on the terminals,it can cause a short.It is meant to weather seal the connector.
Mike Cignarella
1998 EV
2008 Wing
2015 K1600GT
« Reply #15 on: March 05, 2016, 10:24:02 AM »
 Vaseline .
Offline pehayes
« Reply #16 on: March 05, 2016, 11:19:14 AM »
CAIG DeOxit.
I have both the spray and the tiny bottle of liquid.  I prefer and commonly use the tiny bottle so I can control where it goes and where it doesn't.  Should last a lifetime.
« Last Edit: March 05, 2016, 11:20:02 AM by pehayes »
« Reply #17 on: March 05, 2016, 11:26:33 AM »
CAIG DeOxit.
I need to get a bottle.  There have been plenty of times that I coated a lot of unrelated parts with spray.    :laugh:     But then when it's something like a potentiometer with a small opening in the housing, a blast from the sprayer is the only way to get the stuff where it's needed without a lot of extra work.
« Reply #18 on: March 05, 2016, 11:44:48 AM »
Needless for me to say that Wayne has it covered.  :smiley: Oh, yeah.. put Dielectric grease on everything. I'll get another Guzzi that won't run.. cheap.  :smiley: :boozing:
And DeOxit? I can't begin to tell you the things it's *fixed* for me.
« Reply #19 on: March 05, 2016, 01:05:44 PM »
 :thumb: :1:
Offline MGPilot
« Reply #20 on: March 05, 2016, 07:51:34 PM »
Any product should be used sparingly. The logic for dielectric grease being nonconductive is that it doesn't create a short. I have Deoxit. Which you use may depend somewhat on the physical nature of the connection.
Or.....like everyone else, wait or the toast to burn and just scrape it afterwards.
Offline pikipiki
« Reply #21 on: March 06, 2016, 01:19:36 AM »
My alternator connector had been smothered in some kind of grease, it heated up. which was confusing when it looked like someone had made a lot of effort to keep it right, cable tie secured too
Online Gliderjohn
« Reply #22 on: March 06, 2016, 06:33:00 AM »
Seriously, what was di-electric grease developed for?
Back in central KS
Offline swordds
  • (504)234-9011
« Reply #23 on: March 06, 2016, 07:23:55 AM »
I use Tef-Gel on my sailboat fittings and electrical connectors, cost a lot but a little goes a long way and many boaters (including myself) share by it. Available in a syringe applicator or small jar,it is not an insulator.
2016 V7II Stone
2016 Suzuki TU250X (lost in the great flood of ought 16)
In the future I will strive to tolerate everything except intolerance and to hate nothing except hatred.
« Reply #24 on: March 06, 2016, 09:02:51 AM »
I first encountered it long ago as an anti-corona sealant to be used on color TV sets. The 24,000 - 25,000 volt high voltage connection would sometimes be a leakage problem. Dielectric grease would insulate it.
When they started using the high voltage ignition systems and large spark plug gaps on cars, some manufacturers had you apply some to the spark plug boots and at the distributor. Again, a great high voltage insulator plus water resistant. I also read an article from Chrysler or Ford, where they warned of the damage it would do to the electrical contacts and how they had found that the vapors can travel a long distance inside the wire insulation and damage a contact. I had not had any luck finding the source of that article though.
Online John Ulrich
« Reply #25 on: March 06, 2016, 09:03:57 AM »
CAIG DeOxit.
$14.99 delivered from Markertek    :thumb:
« Last Edit: March 06, 2016, 09:07:33 AM by John Ulrich »
Eagan, MN & Scottsdale, AZ
MN MGNOC Rep  L#800
« Reply #26 on: March 06, 2016, 09:21:03 AM »
Corroded fuses were the cause of the fuel pump "failure" on my EV.  It wasn't until I had a break down a Cedar Vale that Rudy was checking the fuses that we figured it out after an intermittent year of putting up with this.
I found some Electrical Contact Cleaner and Lubricant at Radio Shack.  In fact I purchased it a couple years prior to "fix" the scratchy crossover switches on my 40 year old stereo speakers.
I had never encountered corroded fuses before and didn't even notice it when I was examining them when I was troubleshooting
No problems in a year's time after cleaning the fuse block and replacing the all the fuses.
« Last Edit: March 06, 2016, 05:39:14 PM by LowRyter »
Offline MGPilot
« Reply #27 on: March 06, 2016, 03:28:05 PM »
Thanks for this suggestion!  Seems perfect for what I had in mind.
Offline Groover
    • Scooteropolis
« Last Edit: March 07, 2016, 08:12:46 AM by Groover »
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline MGPilot
« Reply #29 on: March 07, 2016, 09:51:02 AM »
ACF-50 and Corrosion X are popular with the aviation crowd.....and actually with the Amphicar crowd. I have only seen them used on structural parts rather than electrical connections, but people may simply not be leveraging their full capabilities.
