Author Topic: This sounds like it could be a pretty good Big-Block deal, to me..  (Read 6931 times)
Offline SLDMRossi
https://miami.craigslist.org/pbc/mcy/5598651096.html
As usual, no relation to Seller, etc.
Steven Rossi
CT-RI MGNOC State Rep.
East Haddam, CT
Re: This sounds like it could be a pretty good Big-Block deal, to me..
« Reply #1 on: May 24, 2016, 09:39:22 PM »
It does look like a good deal in the making.  As a small point, I believe the crash bar was stock.
Offline SLDMRossi
« Reply #2 on: May 24, 2016, 09:47:24 PM »
Since he starts off by floating the number of $3K, I think that opportunity is knocking!
SR
Offline Two Checks
« Reply #3 on: May 25, 2016, 05:44:08 AM »
Yep, crash bars are OEM as is the c-stand. Nice bike.
1987 1000 SPII "Il Duce' II"
Offline HDGoose
« Reply #4 on: May 25, 2016, 06:57:50 AM »
If only...I had space.
« Reply #5 on: May 25, 2016, 08:00:10 AM »
I wonder why he taped over the neutral indicator instead of fixing it.  I can't fault him, I guess, since I just taped over the low washer fluid light in my van while on a trip, rather than stop and fill it.   :laugh:
Online LeRoy
« Reply #6 on: May 25, 2016, 08:11:03 AM »
Nothing wring with that,  unless you had to stop and buy the tape...
LeRoy (Bob Sharp)
Rochester, MI  U.S.A.
'83 1000SP (as of Oct. 15)
« Reply #7 on: May 25, 2016, 09:15:21 AM »
 :laugh:  Very true.  In this case, I mentioned the flashing light and my daughter grabbed a roll of black tape that happened to be next to her.  We both got a good laugh as she tore a rectangle of tape and I put it in place.
That reminds me, I still need to fill the washer tank.   :laugh:
Offline Curtis Harper
    • Harpers Moto Guzzi
« Reply #8 on: May 25, 2016, 10:20:12 AM »
Mille GT is a great bike. Someone grab that thing up.
www.harpermoto.com
1-816-697-3411
curtis@harpermotocom
« Reply #9 on: May 25, 2016, 10:42:05 AM »
Right.  Anyone who has been looking for a really nice Tonti Guzzi would be nuts to not at least go look at this one.
Offline bigbikerrick
« Reply #10 on: May 25, 2016, 01:58:19 PM »
Very nice looking Mille! Those are really handsome bikes....especially in red!
Rick.
Online sdcr
« Reply #11 on: May 25, 2016, 04:35:05 PM »
Steven Rossi
East Haddam, CT
Very sweet looking Mille. Thanks for posting.
Does anyone know if the spoke wheels are tubeless?
Did the 91 have electronic ignition, or would it have the dual point set up?
1983 Moto Guzzi Le Mans III
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
Offline redrider90
« Reply #12 on: May 25, 2016, 05:39:22 PM »
Do not understand the 91 title as they were not imported to US. Only 89 and 90 came in to US. Points on 89, and electronic on 90.
Mille's had only 35 mm fork and small valve engine. Euro model had midvalve 71 HP engine. I do not know if they upgraded the Euro model 91-92 to 40 mm forks. But the 93-94 Strada had 40 mm forks and the mid valve engine. I was a Mille with a little different body work and I believe the same electronic ignition as the 1000s (diplex or something like that).
« Last Edit: May 25, 2016, 05:49:36 PM by redrider90 »
Red 90 Mille GT
Offline jbell
  • Some progress
« Reply #13 on: May 25, 2016, 06:23:50 PM »
Very nice looking bike and if they are willing to take $3K, sounds like a very good deal.  I thought the Milles had alloy wheels?
'76 Guzzi T3   Future project
'78 Guzzi G5  Current project
'81 Guzzi G5  Organ donor
'92 BMW K75RT  On the road
Offline Idontwantapickle
« Reply #14 on: May 25, 2016, 06:33:46 PM »
It looks to have something Guzzi has left off of their bikes for decades. Cupholder.
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
« Reply #15 on: May 25, 2016, 06:49:29 PM »
As I understand it, wire wheels were optional, but I don't know if all regions of the world had the option.
Offline NC Steve
« Reply #16 on: May 27, 2016, 12:01:06 AM »
No, unfortunately the spoke wheels require tubes.
On the upside though, they are aluminum Akront rims
'16 Triumph T100
Past:
'19 RE Himalayan
'07 Honda ST1300
Mark Twain
Offline SPScottNT
« Reply #17 on: May 27, 2016, 07:35:47 AM »
Is the wrinkle black finish on the handle bar clamp stock for this model?  Looks like the engine case is blacked out as well.  Again, is that the stock finish?
I once bought a bike on which the PO had taped over the hi-beam indicator.  I rode it for a year before I got around to pulling the tape to fix it.  Turned out it the light worked just fine - I guess the PO just didn't like the bright blue indicator in the dark.  Maybe someone will get an easy fix like that with the neutral indicator on this bike....
« Reply #18 on: May 27, 2016, 08:33:25 AM »
I'm not sure how upside that is... I had to replace the front Akront on my Mille because it was cracked at every spoke hole.  I'm now watching for cracks in the rear Akront.  I've heard that this is not an unusual thing for Akront rims, although it's not an everyday problem either.
Offline NC Steve
« Reply #19 on: May 27, 2016, 09:31:06 PM »
I've heard about Akront rims cracking as well, but I believe it's a hit or miss condition. My '89 Mille had mileage in the 40Ks when I sold it, and although the Akronts needing a good scrubbing to combat oxidation, there was nary a crack anywhere. That should be one thing to put on the "Close Inspection" list.
'16 Triumph T100
Past:
'19 RE Himalayan
'07 Honda ST1300
Mark Twain
