Yes, absolutely you wan to use only 10W60. You can find it easily on line. Others will chime in, but there is a very real reason for only using 10w60 in this motor.
Motul 7100 in 10w60...... delivered free to your door........http://www.motorcycle-superstore.com/21118/i/motul-7100-synthetic-oil-4t
Thanks. I just ordered six quarts of the stuff. Only two quarts available, so I guess I have to wait longer for the other four. I never even heard of 10W60 before.I see the oil change capacity is 3.7 quarts with the filter change. So I have an extra couple of quarts.What is the oil filter type? Is the 2016 and 2015 use the same oil filter? I noticed the K&N website had a listing for the 2015 Stelvio, but said for the 2016 "no products available." I assume they just are not up to date, but I better be sure, so what type / number of oil filter is it?I will probably pick up my new bike in a week or so.-Don- Reno, NV
Hi, Don.Congrats on the Stelvio!You'll need both the filter and the correct wrench. You can find them here:http://www.mgcycle.com/index.php?main_page=advanced_search_result&search_in_descripti on=1&zenid=bf3edc7a5531dfb75433e0766cabcc3d&keyword=Hf551&x=0&y=0Edit:. They also sell the Motul 4L for less than Motorcycle Superstore. Shipping not included, though.Cheers,Shaun
Thanks for the info. BTW, do you know if the 2016 Stelvio uses the same oil filter as the 2015 and earlier Stelvios? The reason I ask is because of the K & N website that says the 2016 filters are NOT available, but the 2015 filters are. -Don- Reno, NV
It's the same filter.Congrats on the new bike! :-)
As an aside, I wouldn't hesitate to use either the OE UFI filter or the HiFlo, which are of very good quality. It's not uncommon for a respected dealer (Moto International, for example) to ship a HiFlo if you just ask for an oil filter. I've been very happy with them. Sorry, no experience with the K&N, but be aware that clearance around the filter is tight as it is recessed into the sump very deeply, and you really need the special wrench to get it off and on easily. Some filters have a different number of flutes, so require a different wrench. Just be sure what you get fits well, and that you get the matching tool for the filter. Cheers,Shaun
You will most likely need the fluted wrench to remove the stock filter. You won't be able to use a band type wrench or a three-finger grip wrench.... there is not enough clearance to get them onto the filter.
Your dealer should be able to assist you.
"should" being the key word. Odds are the dealer is using 20w50 and just not saying anything.
OP, you show your location as sometimes Auburn, CA. I don't know your closest dealer, or who you purchased from, but Elk Grove Power Sports in Elk Grove, CA is an excellent Guzzi dealer and carries Motul 7100 10w60 in stock.
I will still buy the old filter wrench for the stock filter, just like I did for my other bikes. But I will probably only use it once and use the K&N filters after, just as I have done with my other bikes.But then I can use and remove either type of oil filter.-Don- Reno, NV
