Author Topic: Half Plastic Fuel Filter in 2013 V7 Stone  (Read 4754 times)
Offline SmithSwede
  • I don't want a pickle
« on: March 04, 2017, 01:09:21 PM »
I had the tank off anyway, so I went ahead and replaced the OEM fuel filter.
My 2013 Stone did have the controversial half plastic/half metal filter.
On the other hand, after 3.5 years of service and almost 50,000 miles, the original filter looked just fine.  Plastic was not budging or soft, and everything seemed sturdy and intact.
I went ahead and replaced it with an all metal filter.   But given my own experience, this half plastic filter issue may not be worth fretting about.
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Offline SportsterDoc
Re: Half Plastic Fuel Filter in 2013 V7 Stone
« Reply #1 on: March 04, 2017, 03:18:34 PM »
What years have that half and half filter?
23 V7-850 23 Yam XT250 18 Yam Bolt  22 Triumph St Twin  20 CanAm Ryker 14 Honda CB1100 18 Yam XT250 16 MG V7II 17 Yam TW200 12 Triumph Bonnie 02 Sportster 1200S 03 Sportster XLH883 76 Honda 750F 75 Honda CB360 70 Yam CT1 72 Yam CT2 72 Yam AT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda C11
Offline Kev m
« Reply #2 on: March 04, 2017, 03:20:13 PM »
I concur. I believe I posted when I changed mine (had tank off to do the regulator anyway) the I managed to pressurize the more than 3 y/o filter with more than 100 psi and it didn't separate.
Doc, AFAIK all Guzzis for at least the last decade.
« Last Edit: March 04, 2017, 03:21:54 PM by Kev m »
« Reply #3 on: March 04, 2017, 04:27:23 PM »
That may be, but IF it does fail, the bike won't run...period.  Why not upgrade while one is already in the tank? :grin:
Offline sib
« Reply #4 on: March 04, 2017, 05:17:43 PM »
I changed out the half-plastic filter on my '13 Stone, because back then there seemed to be a bit of panic on the forum about separating filters leaving riders stranded.  But the panic has since died down, and no more than one or two cases of separating filters were ever documented, so I'm leaving my '16 Stone alone.  I don't even know what kind of filter it has installed.  No problems at 13,500+ miles.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline malik
« Reply #5 on: March 04, 2017, 05:31:57 PM »
And mine on the '10 V7C still seemed to be working well when I changed to the metal tank at 164,000km.
Offline Kev m
« Reply #6 on: March 04, 2017, 05:56:01 PM »
At this point I suspect we've proven that the filters will not fail unless there's a defect, which in essence means your argument could be used to suggest replacement of anything on the bike from the ECM to the fuel pump prophylactically because "if they fail..."
« Reply #7 on: March 04, 2017, 06:33:24 PM »
Prophylactics have prevented many a heartache...you pays your money and you takes your choice.
Offline Kev m
« Reply #8 on: March 04, 2017, 06:51:51 PM »
Perhaps, but when the chance of pregnancy is infantismally small (think Clinton scandal) they're wholly unnecessary.
« Reply #9 on: March 04, 2017, 07:04:59 PM »
Who is the manufacturer of the half plastic filter?
« Reply #10 on: March 04, 2017, 07:37:54 PM »
Test 500 or so and let me know how that goes...
Offline SmithSwede
« Reply #11 on: March 04, 2017, 08:53:07 PM »
Malik:
You need to stop wasting time on the Guzzi forum and go ride your small block.   Only 164,000 km?  Pathetic!
Go find your keys, wash the cobwebs off the bike, and get that little Guzzi back on the road!
 :grin:
« Last Edit: March 04, 2017, 08:55:13 PM by SmithSwede »
Offline Zoom Zoom
« Reply #12 on: March 05, 2017, 07:50:17 AM »
It has been assumed for some time that the additives in fuel, (ethanol), play a big part in the degradation of the plastic. I would **guess** that different blends will have varying effects. That being said, it is also entirely possible that the composition of the plastic part of the filter has also changed since they first came on the scene, IDK.
Early on, the filter I removed from my Norge was so soft and pliable that I was actually surprised it had not separated.  That was 2 years old and 11K miles at the time. It was very soft and bulging out.
In any event, you roll the dice and take your chances. Do whatever makes you feel comfortable.
John Henry
« Reply #13 on: March 05, 2017, 08:28:38 AM »
What John Henry sez.. my 07 Norge was ready to fail, too. About 10K miles.
Offline Kev m
« Reply #14 on: March 05, 2017, 08:59:10 AM »
My 06 Breva 1100 filter looked fine after 3+ years of ethanol.
« Reply #15 on: March 05, 2017, 11:44:05 PM »
IIRC i thought I read the the manuf of that filter (Mehle?) "said"  that model filter (OEM in V7) was not specked for ethanol.
Offline gerryp
« Reply #16 on: March 06, 2017, 06:41:08 AM »
That was a topic of conversation at the 2015 National in New Hampshire.  When I got back I had Hamlin Cycles check my filter and indeed it was the half plastic one...yellow, swollen and  mushy. Replaced at 1500 miles.
