Looks great, Jim! Now you have me thinking about one of these...Cheers,Shaun
No one is offering this service in Alberta that I know of, the closest is in Chilliwack BC. there is the shipping back and forth and the costs quickly add up to clean an engine, transmission etc. I found a write up for this manufacturer on the Laverda Forum, same Weekend Warrior unit the guy bought at Barber's, it was a demo model and he really raved about it. I sat on the fence for a year but after the last acid wash I think my respirator acid cartridges were getting weak and I got pretty sick from the fumes. Life's too short to risk another poisoning and I have a line up of bikes to restore and I will offer cleaning for the local vintage bike guys for a nominal fee to help soften the outlay. Check out the Vapor Honing Technologies you tube videos, they clean carbs, crank shafts, pistons, blocks, etc... pretty amazing results.
Education please Chaps.I thought that vapour blasting didn't have an abrasive media and the advantage was that you didn't have any bits of grit, glass to get out of the nooks and crannies of the blasted objectSo, is the difference actually that glass bead blasting is done dry and this is done wet?
The difference is the process is a scrubbing action, the bead does not smash into the part being cleaned and with the water suspension the media does not embed into the alloy. If you compare a part that has been dry glass bead blasted the part will glisten from light refracting off the particles of fractured glass bead. With the vapor honing process there is no bead glistening on the surface, the alloy is honed (slightly polished). Vapor Honing Technologies recommends a rinse with clean water and air blow gun drying.For carburetors and the cylinder heads I will treat them in an ultrasonic cleaner to be sure I free up any particles that may remain in a tiny passage.
This is tempting but I see they recommend a compressor capable of 15-20 CFM. Is this what you are using?Pete
Speaking of paint, does vapor blasting strip paint? Is in, can you safely clean a factory painted case without damaging the paint, or will it strip it?
Odd. The pics all work today. I gotta say I am impressed. Too bad my shop has no plumbing. I settled for a shop with three different 220v outlets. That has been good enough for me for almost 30 years.Thanks for posting!
That really looks terrific, even the stud threads look clean. Do the glass beads get recycled a few times or are they a total loss? Ya got me thinking but it would also cost me a new compressor.
Hi Jim, I have completely missed this thread! I really really like this vapour honing thing. The parts looks spectacular! If you're ever happen to have a view into the tank or to the slurry pump at some time I would love to see a picture of it. I have to confess that there is not a big chance that I justify spending the 35000dkr (roughly 5500USD) on a brand name vapour blasting cabinet, but I am certain that I could build one with 90% of the functionallity for much less. So I should be very much interested in seeing how they have set up the slurry pump system. -Ulrik
