Author Topic: V11S down for lack of a seal  (Read 4074 times)
« on: July 09, 2017, 05:42:08 AM »
A friend's clutch slave on the V11 sport is belly up. Unless we can come up with a seal, the bike is dead. He can't find one.. how about it WG guys and girls?
 EPDM 3mm square section O-ring seal (30mm ID)
Edit: Oh, forgot to mention. The clutch slave is NLA.
« Last Edit: July 09, 2017, 06:03:34 AM by Chuck in Indiana »
Re: V11S down for lack of a seal
« Reply #1 on: July 09, 2017, 05:54:03 AM »
Let me have a dig tomorrow Chuck.
« Reply #2 on: July 09, 2017, 06:04:06 AM »
In fact looking at the parts break down even though they have different part numbers I reckon the slave is identical between the V11 and the CARC bikes, the difference being one is supplied with a bleed nipple and one without. If you can measure the bore diameter and depth I'll check tomorrow. If it's the same I'll send you a slave AND the nice remote bleeder line so he'll not have to do the grovelling when bleeding the clutch!
« Reply #3 on: July 09, 2017, 07:54:16 AM »
He's already tried the carc slave. They are different. This is second hand info, but I think 32mm vs 30mm dia. on the V11S.
« Reply #4 on: July 09, 2017, 08:01:42 AM »
Maybe get a hold of a Brembo parts guy to match it up to a puck seal.
Offline Scud
« Reply #5 on: July 09, 2017, 08:17:19 AM »
The clutch slave is by Grimeca, not Brembo. But there's a chance that a Brembo o-ring could fit.
Here are the measurements I took from 2000 V11 Sport:
1989 Moto Guzzi LeMans
2017 Husqvarna 701 Enduro
2017 Moto Guzzi Stelvio NTX
2020 Yamaha TW200
Offline Murray
« Reply #6 on: July 09, 2017, 09:04:49 AM »
I seriously doubt the slave would be unique to Guzzi might be worth trying to work out where else it was used I'd start by getting a part number directly off the part and type that number into google.
« Reply #7 on: July 09, 2017, 09:09:27 AM »
In my experience, Grimeca is generally a cheaper imitation of Brembo. Maybe a Brembo seal "would" work. At any rate, if we don't figure this one out, we may have found the Achilles heal of a V11S.
Offline RinkRat II
  • Lake Powell AZ
« Reply #8 on: July 09, 2017, 10:10:09 AM »
I know it's not oem but Kaman, Motion Ind. or any good bearing house or Hydraulic shop should have that nowadays. If all else fails I know they make O-ring kits to build your own.   Plan B... I have a spare used complete slave Lemme know :popcorn:
    Paul B :boozing:
« Reply #9 on: July 09, 2017, 10:20:09 AM »
Thanks, Paul.. I'll pass this on.
« Reply #10 on: July 09, 2017, 10:38:38 AM »
Does the O.D. Matter? There is a major seal dealer / manufacturer here and I can usually get any type / size of O ring. I can check Monday if you like
Cheers
Jim
Offline dsrdave
« Reply #12 on: July 09, 2017, 02:10:14 PM »
Racing brake calipers like wilwood use a square seal, you can substitute a standard round o-ring on them.  The mfg . prefers the square type cuz you get a little bit more pull back of the piston (Good for clearance on brakes) but they work well with a round type also.  The pressures are FAR less on a clutch slave verses a brake caliper.  I would use an appropriate round o-ring.
Offline acogoff
« Reply #13 on: July 09, 2017, 03:27:50 PM »
     To get by you may try one of these buna xrings. I see they are available in that size.
      https://www.mcmaster.com/#o-rings/=18fd4vn
« Last Edit: July 09, 2017, 03:29:37 PM by acogoff »
Marshall County Minnesota USA
« Reply #14 on: July 09, 2017, 04:58:21 PM »
https://www.mcmaster.com/#o-rings/=18febsl
square profile silicone o-rings
Offline Groover
    • Scooteropolis
« Reply #15 on: July 09, 2017, 08:33:34 PM »
If you haven't already, maybe try a Napa store. I found them to be a good place to find odd things like that. The "main store" n the area is the ones that may have the all the stuff on hand and the service guys/gals are more likely to have seen something like it that may work. Typically, I've found Napa counter guys very willing to help and take their time to dig a little and come up with something. Good service in my experience. Good luck.
Napa, where is my check?  :azn:
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #16 on: July 09, 2017, 09:57:03 PM »
I have some manner of Guzzi clutch slave cyl in my stash.  If you snap me a pic I might be able to match it.  I was after the left side pump for a project and had to take the entire system.  So I have no use for the slave.
« Reply #17 on: July 10, 2017, 06:12:16 AM »
Thanks to all that have posted. He's in Tennessee, and I haven't seen what is going on. He has found a supplier that will make some for 13 bucks, minimum order of 10, so that ought to sort it.
