Author Topic: im now getting any oil pressure on my 98 ev motor!  (Read 9333 times)
Offline troyhamilton
  • Dr frankie
« on: July 18, 2017, 10:06:19 AM »
I cant get it to prime! This is the motor i got from Muley. Ive tryed spining it over with no plugs a few times. i only have a test light hooked to the sending unit. but no oil is coming up to my top end. light stays lit. any ideas? it was lying on its side for several years. i have 3 quarts of oil in it. nothing. i dont have the oil vent box on the  motor or the dizzy in. valves have been adjusted. any ideas?
« Last Edit: August 04, 2017, 09:17:33 PM by troyhamilton »
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
we need a tech section!
Offline guzzista
Re: im not getting any oil pressure on my 98 ev motor!
« Reply #1 on: July 18, 2017, 10:15:49 AM »
You might just have to invest in a cheap Harbor Freight oil pressure gauge. The fitting I believe is 12mmx 1.5. Only then you can be sure.
« Reply #2 on: July 18, 2017, 10:25:29 AM »
Might just be a bad oil pressure switch. Remove a valve cover and see if any oil is reaching the rockers or loosen the banjo bolt where the oil line to the heads is secured to the block and see if oil squirts out there when you crank it.
  • Dr frankie
« Reply #3 on: July 18, 2017, 10:30:18 AM »
rockers are dry. no banjo on my ev.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
« Reply #4 on: July 18, 2017, 10:34:08 AM »
Sure there is: right near the oil pressure switch, down on top of the engine case. Or just remove the oil pressure switch and see if oil squirts out there.
Banjo bolt right at the "Y":
  • Dr frankie
« Reply #5 on: July 18, 2017, 10:36:58 AM »
yeah i thought about it after i typed it. it is too hot in dixie! 84 already
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
Offline yogidozer
« Reply #6 on: July 18, 2017, 10:51:53 AM »
same here in Ct., hate it
Online Wayne Orwig
« Reply #7 on: July 18, 2017, 10:54:53 AM »
If the pump is totally dry, it may not want to prime. I had that once,  on a motor that was dry for a long time. I buttoned the motor up tight. pulled the oil pressure switch, and put a few PSI of air pressure in through the oil dipstick hole using a rag wrapped around an air line. After a time, a little oil started to ooze out the pressure switch hole. All was well after that.
Online Chuck in Indiana
« Reply #8 on: July 18, 2017, 11:07:24 AM »
Standard procedure on dry VW engines is to pack the pump with lithium grease for first startup. Wayne's method ought to work, too.
  • Dr frankie
« Reply #9 on: July 18, 2017, 11:14:26 AM »
that might work if i had it apart that far.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
« Reply #10 on: July 18, 2017, 11:20:16 AM »
Go with Wayne's then.. I think Charlie has posted he primes engines that way. Takes a while with low air pressure.
I'll see if I can find that thread..
  • Dr frankie
« Reply #11 on: July 18, 2017, 11:25:41 AM »
cool!
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
« Reply #12 on: July 18, 2017, 11:26:50 AM »
I have in the past, on ones that won't prime by themselves. I drilled and tapped a drain plug for a schrader valve and screwed that in the dipstick hole. 5 psi is all it usually takes.
« Reply #13 on: July 18, 2017, 11:37:33 AM »
Thanks, Charlie.. I couldn't find that thread.  :smiley:
Online Wayne Orwig
« Reply #14 on: July 18, 2017, 12:13:44 PM »
With my luck, at some point the air line would come off of that schrader valve, it would not work right, and there would be a lot of pressurized oil everywhere.  :boozing:
« Reply #15 on: July 18, 2017, 12:34:52 PM »
On the one I made, the core isn't in the schrader valve and I pressurize with a $4.99 Harbor Freight tire inflator with gauge. Haven't made a mess yet, but there's always that chance!  :grin:
  • Dr frankie
« Reply #16 on: July 18, 2017, 12:38:51 PM »
i bet my landlord would like to see the garage sprayed with oil...ill roll it out side at daylight to hot now, done  hit 90...very humid!
 :evil:
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
« Reply #17 on: July 18, 2017, 01:58:55 PM »
Pull the pressure switch and crank -- see if oil comes up the galley.  Did you fill the filter with oil?
  • Dr frankie
« Reply #18 on: July 18, 2017, 02:07:52 PM »
no i didnt. might drop the pan and do that. didnt think of it
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
  • Dr frankie
« Reply #19 on: July 18, 2017, 04:51:14 PM »
i bet you could fill the oil system from the top too. if you had no air
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
Online LowRyter
« Reply #20 on: July 18, 2017, 06:05:07 PM »
determine if the pan gasket hasn't been installed upside down.
It's easy to do.
don't ask me how I know.   :undecided:
« Reply #21 on: July 18, 2017, 06:35:09 PM »
It's no big deal.. trust me on this one.
« Reply #22 on: July 18, 2017, 07:32:03 PM »
It's easy to do.
  • Dr frankie
« Reply #23 on: July 18, 2017, 09:23:55 PM »
i think the gasket is instaled
 correctly
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
  • Dr frankie
« Reply #24 on: August 04, 2017, 12:30:55 PM »
I was wr  wrr wrrrong. lol its was hot that day. and it finally cooled off. i dropped  my pan and danmmit both gaskets were bass ackwards! filled my filter too. pump is ok. try sometimes this week to retime and drop my dizzy. and readjust my valves
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
Online LowRyter
« Reply #25 on: August 04, 2017, 12:47:33 PM »
been there, done that.
glad you found it.
Offline tazio
« Reply #26 on: August 04, 2017, 12:52:21 PM »
And THIS is why I love the Wild Goose Chase and it's premium members! :thumb:
No point in naming y'all, wouldn't want to leave someone out !!
 :bow:
1967 Kawasaki 650 W2TT
1966 Triumph Bonneville
Offline nbags
« Reply #27 on: August 04, 2017, 01:30:30 PM »
remove oil pan fill filter with oil remove oil pressure switch and try to fill with oil  remove plugs and crank it over pressurizing crankcase does work but do not over pressurize could push seals out.Some parts stores carry an engine oil primer you can rent for a small fee that works pretty good.
« Reply #28 on: August 04, 2017, 01:58:37 PM »
I would definitely stop drinking while you wrench.
  • Dr frankie
« Reply #29 on: August 04, 2017, 02:09:54 PM »
I havent boozed in years
miss it lol :boozing:
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
