Author Topic: Cal 2 auto using Convert parts?  (Read 3029 times)
Offline brider
« on: September 30, 2017, 09:02:41 AM »
I know this has been discussed before, but I looked and didn't hit the right "buzzwords". Please steer me to the build threads if they exist.
Is it possible to use Convert timing cover, cam, TC, tranny, swingarm, etc, to build a Cal 2 Auto? Is it all just bolt-up?
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'05 KTM 950 Adventure
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
Offline derekwiltshire
Re: Cal 2 auto using Convert parts?
« Reply #1 on: September 30, 2017, 10:13:59 AM »
If memory serves me well, then all you need is the Torque Converter, Gearbox and Clutch and the Final Drive Box from the convert
Offline Rick4003
« Reply #2 on: September 30, 2017, 07:48:26 PM »
Maybe check up on rodekylls trike thread. I know he had an hydro engine with the convert torque converter on and later installed a breva engine in his.
Sent from my SM-A520F using Tapatalk
Moto Guzzi Ambassador - 1967
Yamaha FZR 600 - 1996 - SOLD
Offline Idontwantapickle
« Reply #3 on: September 30, 2017, 09:41:52 PM »
Yes, it can be done because Guzzi did it! There were California IIs sold with that drivetrain.
You will need all the convert goodies. Cam, front engine cover, hoses, fittings, oil tank, shift linkage, flywheel, torque converter, transmission, U-joint and shaft, and rear drive box. I may have overlooked something.
But to your main concern, it is a bolt up project.  The only big hassles are swapping the cam and relocating the ignition coils.
Hunter
« Last Edit: September 30, 2017, 09:49:34 PM by Idontwantapickle »
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Offline brider
« Reply #4 on: October 01, 2017, 09:13:33 AM »
Hunter
Thanks! Just wanted to see if there was something different about that Cal II Tonti frame/engine that made the timing covers unique.
The Cal II swingarm was longer, so I guess as long as the rear drive box and tranny from the Convert are used, it's all good?
Wonder why there aren't a lot of conversions....seem s like a lot of Convert parts floating around.
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'72 Red Eldo
'74 White Eldo LAPD
'06 Gas Gas EC300
'86 LM IV
« Reply #5 on: October 01, 2017, 10:33:29 AM »
Converts are an acquired taste, not many folks would go to the trouble although it has been done to most Guzzis that use the similar driveline.
For the Cal II you may need a unique to that model U-joint/shaft assembly due to the longer swing arm. You will need to consult a knowledgeable older dealer like Harpers, MG Cycle or Cycle Garden to find one. I doubt that the shorter swingarm from the Convert would work satisfactorily with the Cal II frame.
Hunter
Hunter
72 Eldo
84 BMW R100RS
Offline 5154guzzi
    • Team Subtle Crowbar
« Reply #6 on: November 02, 2017, 11:30:53 AM »
The longer Cal II automatic driveshaft can be hard to find, it has 10 splines at the U joint and 20 were it connects to the convert rear end. I looked around a long time and got one out of Europe, TLM.  The shorter convert swingarm will fit, but shock length will likely need to be changed and handling will be changed as mentioned.
