Author Topic: v50-v65 fork swap  (Read 8912 times)
Offline rhonddaman
v50-v65 fork swap
« on: November 04, 2017, 10:03:30 AM »
asking for info regarding v65 forks/headset fitting to a v50, I have chance of  a complete v65 setup and as I have incomplete v50 setup would like to upgrade (if that's the right word) any info appreciated, thank you.
Re: v50-v65 fork swap
« Reply #1 on: November 04, 2017, 11:22:55 AM »
Should be a strait swap, they used the same frame. The headset of tapered rollers is a good upgrade from the ball set.
Offline rhonddaman
« Reply #2 on: November 04, 2017, 11:26:04 AM »
thank you. its appreciated :thumb:
Offline SED
« Reply #3 on: November 04, 2017, 12:57:07 PM »
It's pretty simple but it is not a strait swap - at least not from V65SP to V50 Monza (and I believe you will find it's the same on yours).  The V65 steerer tube is about 25mm longer than the Monza's so it needs to be cut to length and rethreaded.  Maybe the V50 triple trees could be bored for the V65 fork stanchions but it seems they would be weakened significantly.
The V65 fork tubes are also about 20mm wider center to center so you need the V65 axle and front wheel, or the spacers from it to put under the disk rotors. The spacing and stanchion diameter may also interfere with a fairing or headlight bracket.
Because of these complexities (and I'd recently rebuilt the V50 forks) I've not yet made the swap.
Post a report when you do it.
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
Offline Psychopasta
« Reply #4 on: November 04, 2017, 02:21:38 PM »
This ^^^^. Yes, please do!
- P
V50 Monza 1981
Moto Guzzi V7 Stone Special 2023
Honda Goldwing 2019
Aprilia Tuareg 660 2023
Ancient A65 Bitsa, in pieces
« Reply #5 on: November 04, 2017, 03:49:30 PM »
don't cut and rethread the stem yet. you can just make some cups for  the tapered roller bearing conversion which needs a longer stem. you may get lucky
Offline rhonddaman
« Reply #6 on: November 05, 2017, 05:16:13 AM »
Ok thanks for the feedback, waiting for forks to arrive next week, will keep updated.
« Reply #7 on: November 05, 2017, 08:52:20 AM »
No need to make them even: http://guzzipower.com/store/Smallblockbearing.html
Offline rhonddaman
« Reply #8 on: November 09, 2017, 07:19:52 AM »
just arrived from Netherlands,
russian photo sharing
Offline huub
« Reply #9 on: November 09, 2017, 10:07:29 AM »
looks  like  a set of lario forks.
not the best choice, on these the front axle has been offset, to compensate for the 16 inch front wheel.
the added trail might do funny things with the handling of your v50 with 18 inch wheels.
only way to find out is to fit them..
Offline rhonddaman
« Reply #10 on: November 09, 2017, 01:42:58 PM »
oops  :grin:
« Reply #11 on: November 09, 2017, 03:45:22 PM »
A guy on the Guzzi rally I have just been on had a very nice original Stornello. :thumb: He had put a Monza front fork and disc brake set-up on it. Did not get to discuss if there were many problems but it looked really good.
Offline rhonddaman
« Reply #12 on: November 10, 2017, 12:36:25 PM »
I am having trouble finding spindle/axle for these forks the left fork spindle hole is 25mm forks width outer to outer 210mm anyone know?
Offline rhonddaman
« Reply #13 on: November 11, 2017, 03:44:02 AM »
pictures hoster
  this is the  lario spindle, will need wheel or with the assistance of my student friend from Colchester turn it down to fit v50 wheel?
Offline rhonddaman
« Reply #14 on: November 11, 2017, 06:20:34 AM »
located spindle but its not getting any easier, either need 40x20x12mm wheel bearings? or swap wheel.
Offline rhonddaman
« Reply #16 on: November 11, 2017, 07:18:36 AM »
thanks for that, only need 40 o.d not 42, only place seen so far is china Alibaba. cant find in U.K.
Offline huub
« Reply #17 on: November 11, 2017, 10:00:58 AM »
sorry , picked the wrong one ,
the piaggio MP3 125 uses 20x40x12 in the engine cover
at your friendly piaggio dealer with part number AP8128186
https://www.ebay.de/itm/BA-BE-114-Cuscinetto-20x40x12-da-BANCO-SKF-6204-C4-Peugeot-103-SP-104-105-0-0/162728548554?hash=item25e36098ca:g:frYAAOSwnsZZfdKH
« Last Edit: November 11, 2017, 10:06:51 AM by huub »
Offline rhonddaman
« Reply #18 on: November 11, 2017, 10:27:32 AM »
Please don't apologies, best news i have had today :thumb:
Offline rhonddaman
« Reply #19 on: November 11, 2017, 11:07:37 AM »
down again, although states 40x20x12 its actually 42x20x12, what's that all about? I guess there is no such size due to only 10mm difference between inner and outer dia. gutted.
Offline huub
« Reply #20 on: November 11, 2017, 11:30:31 AM »
have you tried the piaggio part number?
i actually have those 20x40x12 bearings in a bike.
Offline rhonddaman
« Reply #21 on: November 11, 2017, 01:12:01 PM »
tried that part number, although it states 40x20x12  it its really a 6204 which is 42x20x12, no idea why they do that, if you can check size of your bearing it would clear it up, been to all the bearing suppliers and that size appears not to exist?
« Reply #22 on: November 11, 2017, 01:54:28 PM »
Straight vs. strait.  Hey, I don't make this stuff up.   :grin: :grin: :grin:  Good luck on the swap.  Heavier springs and thicker oil???  :shocked:  Lose some weight?   :huh:
https://www.merriam-webster.com/dictionary/straight
https://en.wikipedia.org/wiki/Strait
Offline rhonddaman
« Reply #23 on: November 15, 2017, 02:52:37 PM »
multi hosting
          made a couple of "jumbo" taper bearing housings so will be able to turn them down to accommodate whatever forks I eventually fit.
« Reply #24 on: November 15, 2017, 03:32:55 PM »
That's a nice fix.
Offline rhonddaman
« Reply #25 on: November 15, 2017, 03:44:35 PM »
not to pretty at the moment but plenty of meat to refine when ready, I will try my best to get these forks to fit, learning as I go, its what I do. got my theory test tomorrow fifty years have flown by since I failed my test on a motorbike here in wales 1965, I need to get a move on. if I want to get this guzzi on the road. :grin:
Offline rhonddaman
« Reply #26 on: November 15, 2017, 03:47:44 PM »
 its evolving :wink:
« Reply #27 on: November 15, 2017, 05:47:58 PM »
You should be doing the V9 build.
Offline Diploman
« Reply #28 on: November 15, 2017, 05:59:44 PM »
Nice petrol tank adaptation!  From what model BMW did you pinch it?
2015 KTM 390 Duke
Offline rhonddaman
« Reply #29 on: November 16, 2017, 07:15:59 AM »
k100 lt ,home made fender.
