help me find my short: convert
Topic: help me find my short: convert (Read 3822 times)
DavidF
New Egg
April 24, 2018, 04:53:40 PM »
My 78 convert is coming along nicely. Every time I fix a problem I find a new problem. It's kinda fun until the snow melts here in Vermont.
My current (pun!) problem is a short. The fuse controlling the brake light blows when I apply the brakes, front or back. I replaced and rewired the headlight/directionals, replaced starter switch with Yamaha, rebuilt all the brake cylinders and pistons, and the weird thing, I found a lot of wires that go no where. All other electrics work fine, including the horn, (which is also new), which is on the same fuse.
I have hunted this and I am running out of fuses to test my hypothesis. Any ideas?
fotoguzzi
vee git tooh soon oldt und too late wise -my Dad
Re: help me find my short: convert
Reply #1 on:
April 24, 2018, 08:18:26 PM »
unplug either the front or rear brake light switch to isolate if it's in the F or R ?
rodekyll
Not my real name
Reply #2 on:
April 24, 2018, 09:24:45 PM »
Did I see that the rear lights wiring was fixed?
If something got miswired in the rear you could be sending juice from the switch to the ground, bypassing the brake light bulb. Pull the plugs on the rear wiring and see if it still happens.
Last Edit: April 24, 2018, 09:25:25 PM by rodekyll
John A
No way to slow down...
Reply #3 on:
April 25, 2018, 07:29:25 AM »
Sometimes the plastic sockets for the bulb melt. If you are clever you can replace the socket with a metal one from the auto parts store. I like to add a relay to the brake light just for the hell of it.
Chuck in Indiana
Reply #4 on:
April 25, 2018, 09:25:44 AM »
If you solder a couple of leads on a tail light bulb and install that in place of the fuse, it will light up instead of blowing the fuse. Saves on fuse expense. (Guzzi content)
As an added benefit, you can troubleshoot to your hearts content..
Groover
If it ain't broke, I'll break it.
Reply #5 on:
April 25, 2018, 01:49:48 PM »
Great tips here, I like the bulb as fuse one! If I remember right, the rear brake circuit actually goes through the headlight interconnect, thus the left side switch. Sounds like there were some changes made there? I'd check that direction as well. Any difference if you have the high beams on? I know, doesn't make sense, but neither does that headlight interconnect. A lot is happening in there...
Greg Bender's new harness to the rescue?
Here is a wiring diagram.. have fun! (it's for a G5, should be close if not the same as the Convert)
Last Edit: April 25, 2018, 01:52:47 PM by Groover
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Huzo
Reply #6 on:
April 25, 2018, 02:39:52 PM »
Short what..?
DavidF
New Egg
Reply #7 on:
April 29, 2018, 10:33:27 AM »
Thanks for the tips but after a few days of troubleshooting, I am still confounded. I rigged up a light bulb to the fuse. I have disconnected wires methodically. Both left and right brakes cause the light to glow. When I remove the black wire going to the tail light assembly the fuse light does not glow when the brakes are applied. When I splice in a new wire using aligator clips, the bulb glows. When I removed the tail lights, the fuse bulb still glows.
Any thoughts?
Chuck in Indiana
Reply #8 on:
April 29, 2018, 10:39:17 AM »
Maybe your light socket is grounded?
BikeMike
Hatchling
Reply #9 on:
April 29, 2018, 11:41:43 AM »
David,
If you have an Ohmeter you could remove the fuse and the rear brake light bulbs and check the continuity to ground on the load side of the fuse. There should be no pathway to ground with the brake light bulbs removed and the Ohmeter should show an open circuit. If the Ohmeter shows a resistance to ground or dead short with the light bulb removed then you have a short. In this case you would then trace back each wire in this circuit to isolate / disconnect each to find the source of the problem.
Hope this helps..
Mike
1975 850T Interceptor
1976 V1000 Convert Police
1949 Matchless G3L
Idontwantapickle
The rotation of the earth really makes my day.
Reply #10 on:
April 29, 2018, 12:00:56 PM »
It sounds like you have isolated the problem to the tail light or the wires to it. As BikeMike says you need to check each wire. The tail light wires go through the fender twice and can wear through the insulation at those points. Since it blows the fuse with no bulbs in place then it is before that point but after the switches. Do the parking lights operate correctly? That would indicate that the tail light is probably ok and that the wires for that are intact. It is possible to connect the tail light incorrrectly on some types and cause a short. Disconnect it entirely to eliminate or confirm the tail light as the source.
It seems to me you've narrowed it down to the wire for the brake light beyond the rear brake switch or the tail light assy.
Hunter
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
DavidF
New Egg
Reply #11 on:
April 29, 2018, 01:28:04 PM »
I think you have the right idea and I need to accept it. The wrinkle is that I have found maybe 10 unconnected wires around the bike. A PO must have added extra lights, stereo, trailer. There are a lot of dead ends.
Kiwi_Roy
Reply #12 on:
April 29, 2018, 03:36:33 PM »
I use the bulb in place of fuse method as well, its an old Sparkies trick.
The fault is on the load side of the brake switches (either one) to the stop light so you only have about 3 connections to check.
The diagram someone posted shows a connector near the tail light, pull that apart to eliminate the light itself.
Take the bulb out to make sure it's not that.
Inspect where the wires pass through the fender.
Try jamming the brake on then wiggle every connection to see if it effects the light.
