Have the TPS checked and set
'm new to Guzzi's (this is my first)
Did you know a Guzzi motor likes to rev? it's not like a Harley where you just get in high gear and lug along.. you should rev to over 4k before shifting and can even ring it out to near 7,000rpm. around town riding is best done in 3rd gear mostly, sometimes 4th.. I don't use gear 5 till about 70mph..
regardless as to miles a 98 should be on it's third TPS by now.
It's no myth that they like to rev..mine runs perfect at any speed and can putt along at 1500 rpm anytime so I don't have to run it out... but you can tell it likes that..the only mod is a corectomy to the crossover/muffler in the center. a power commander is totally unnecessary, I'd let you ride mine to see and bet you it runs better than any other 1100 w/a PC. It was perfectly tuned by Doug Lofgren before I got it.but to the OP, on your box (P8) there is a trim screw under a plug that can affect fueling,(mostly idle and low revs) don't turn it more than 1/2 turn each time (then run for at least 10 minutes) and it's not endless if turned more than about 3 revolutions it will disconnect internally. best set with an O2 meter. I wouldn't mess with it unless you have rough running in the lower revs.
One other thing about the '98s is they have the oil temp sensor in the valve cover. If you ride in cooler weather the oil/moisture combo makes a mayonnaise around the sensor insulating it. Clean it up regularly to lessen the richer mixtures.Pete
