Author Topic: relay switch on an 02 Cali  (Read 521 times)
Offline Tony/CT
« on: June 27, 2018, 07:29:19 AM »
A buddy has purchased an 02 Cali. Special Sport and the turn signals have quit. Does anyone know where the relay switch is located on that bike?
Offline Zoom Zoom
Re: relay switch on an 02 Cali
« Reply #1 on: June 27, 2018, 07:40:19 AM »
Assuming it is located in the same place as the '01 EV's I had, the flasher can would be under the right side cover below the fuse block.
John Henry
edit: I might add that this is a turn signal flasher can like we have had for some time on cars prior to the can bus stuff.
« Last Edit: June 27, 2018, 09:11:53 AM by Zoom Zoom »
Offline Tony/CT
« Reply #2 on: June 27, 2018, 07:41:55 AM »
Thanks John!
Offline Vagrant
« Reply #3 on: June 27, 2018, 12:16:58 PM »
if it's not the flasher and I doubt it is find the flasher relay on the diagram on side cover and replace it. smartest thing to do is replace them all with new 5 prongs. at the very least clean them.
2016 V7II, 2017 V7-III Blue special, 2022 V85 the fast red one! 2016 650 Versys
