I would...but only knowing that the forums would be my security blanket.I wouldn't count on a dealer being there to help.
bought first year new generation Dodge Ram 2500 with Cummings. the motor and drive train, solid as a rock. The truck, lets just say dodge won't have to worry about me buying another one of their vehicles. Maybe the newer ones are better, but I will never try one.
From what I’ve seen, the V85 is just a further developed V9 in ADV trim. The V9 seems to have been pretty solid. The rest of the V85 is parts bin stuff that’s proven. The two areas I have concerns with are things I’ve wondered about from the first pics that came out; I don’t think the subframe is strong enough to handle two fat Americans and their luggage without breaking and the swing arm mounting arrangement doesn’t seem up to hard use. Neither of those things would be an issue on a road going version of the bike.
From my reading, it looks like the V85 is quite a change from the V9. I think the internals are much lighter, breathes better and runs up another 1k rpms or so. But maybe it's all hype and it's a parts bin machine?I might add that the 1400 was a new design too. And other than some electronic gremlins and some early cracked crossovers, it's been a solid machine. And I'd be afraid of the electronics/computer on any new bike unless it was from Japan (or maybe a Triumph).
I have had such wonderful luck engine wise and so forth with Guzzis, I don't think I'm "too" concerned with that aspect; yet, I would 2nd concerns with regard to the electronics package. This is the first TFT display for a Guzzi model and it has Navigation capability and a few other bells and whistles. These things are not easy to get right the first year. In fact, just off the top of my head - and if I recall correctly - KTM and BMW has had some issues with their TFT screens. I know for sure the one on my former (Thailand assembled) 390 Duke the TFT was basically Skynet making its own decisions and so forth.
The V85 TT is a bike that gets my attention, but the Tenere 700 coming out in 2020 (only about 15 months away) is trumping this Guzzi offering, at least on paper in my estimation.
The fact of the matter is as yet no real information of any worth has been released. There has just been a lot of meaningless blather and hype.What has been suggested with a matter of certainty is that the motor is still an OHV design with a hemispherical combustion chamber, bigger valves with Ti heads on the exhausts and roller tappets at the bottom end. Another change is the move to a fully dry sump lubrication system. More needs to be said on that a bit later.On the engine management side it's going to use the same 52mm throttlebody and 7SM controller used on the Cali 1400's. Whether the same plenum system is being used we don't know but I'd assume it will.So far there has been no mention I know of of significant changes to the construction of the crank or connecting rods. Something that if they want to get more power out of it they will have to do as they will have to make it spin faster. To enable that to happen you'll need lighter components. Not just crank rods and pistons but also in the entire valve train. While Ti valve heads reduce weight that will more than be offset by the increase of mass in the roller tappets so few, if any, gains there.More in a bit.
The other thing I think I've been able to glean from the various 'Interviews' with people involved in this project is that one of the things that will greatly boost the new engine's power output is the adoption of a full scavenge dry sump system that is designed to reduce the pressure in the crankcase leading to lower parasitic losses from the pumping action of the pistons.Now that may sound all well and good if you're an escaped mental patient or suffer from some basic learning disability that prevented you moving beyond year five in primary school but unfortunately the reality is that if you add another level of mechanical intervention the parasitic losses from that are going to outweigh the benefits! Sorry! That's the way the universe works! Nothing can be done about it. If they have gone down that route it would seem to me to be far more likely they have done so because the volume within the small block crankcase is insufficient to prevent over-pressurisation under sustained, hard, high load, high speed running. Positively evacuating the case will reduce the stress on both seals and the breather system. Mind you, it would seem to me to be a very tough way of going about it!At the end of the day to increase the engine's performance you need to improve its efficiency. There are three efficiencies.Mechanical. That is making things work better with fewer losses.Thermal. Taking the heat created in the motor and using it to heat the gas in the combustion chamber and making it expand or raise the pressure to do more work. Waste less of it as heat radiated or transferred from the motor.Volumetric. Getting more gas into the cylinder and combustion chamber so that when it is heated the pressure rise will be greater and therefore produce more work.There are no *Magical* improvements that happen simply because time has gone on and things have 'Got Better'. That 'Better' has to be quantified and explained otherwise it's just so much more unicorn farts!Getting back to the original question though. Should a first year model be avoided? Well essentially all of the tech is very old school. Even the electronics have proven pretty reliable in the Cali series. Sure RSV-4's used in anger will shed the heads of their two part exhaust valves like confetti if provoked but we're looking at a massively more highly tuned and 'Hotter', (Literally!) motor with a much, much higher engine speed and critical component loads. I see no reason why it shouldn't be a reliable thing as long as the people servicing them are trained correctly and actually do what they are supposed to!I hope they are as reliable as an anvil and sell by the squillion.My next motorbike will be either an SWM or an AJP.Pete
Hmmm... When I follow this thread I come to the conclusion most here think the V85TT is constructed basically by the same people who did the detail design of Lemans III and later, the small blocks, the not-rollerized four valves and so on. But this obviously is not the case. This bike is completely designed by Aprilia. They took the basic dimensions of the old smallblock and made a new motorcycle. This of course incorporates the danger that they made something wrong that has to be sorted out ASAP, but I think they simply worked professionaly and delivered a sound design. I think this cannot be compared to the new developments in Guzzis past and their partial failure in the first years.
Research past history,then make a decision and roll the dice;)
