The Stelvio guards will work if you take some aluminum stock and create brackets to extend the attachment point.
See attached. It’s easy enough. Get the guards and fit them on, you’ll see how much length is needed. Chop/grind the aluminum stock to fit - I used a Dremel. I rounded mine off to get rid of sharp corners and painted them black (knowing the black would wear off the aluminum, but no big).
