this is one of those things about the modern world that I just can't understand.If you put in the amount that the manufacturer specifies, which is way too much, it spits oil back into the airbox and destroys your throttle bodies. the cost of replacing the throttle bodies is essentially prohibitive.yet, the manufacturer sees no reason to issue a notice, or anything like that. Not even something as simple as telling us how much freakin oil to put in our bikes???Moto guzzi - built to last until your next one.Sadly the case for pretty much all products now.To the OP - I have the magic figure written down somewhere, will post it up here if I find it at some point. Huzos bike has done many more miles than most, so I'd go with his guidelines.
Unlikely it will destroy your throttle bodies......... May spit about 1/2 a quart into the airbox, which may saturate your air filter, and MAY get some of the blowby into the stepper motor which MAY gum it up, but unlikely to destroy.
word over on the ghetto is that the oil picks up dirt and turns into a paste and gradually destroys your finely tuned throttle bodies until that once beautiful and proud fine mist spray pattern becomes aught but a stale dribble.
This concept that you need to fill the oil filter, on the hope the motor gets up to pressure 1/4 a second faster is WAY over kill. I have over 55,000 miles on my B11, and stopped doing that pain in the butt ritual after the second oil change. And in truth, I couldn't notice any difference in when the oil pressure light goes off. Think about it, I change my oil about every 5000 miles, so that's 20 oil changes in 100,000 miles. Even if it were true that the oil pressure would come up 1/4 second faster (which I don't believe) that would be 5 entire seconds over a 100k miles! That would mean nothing to an over built beast of a motor that is the old school Guzzi big twin.
Indeed, sounds like you're pretty fuzzy as I am. I am just pulling the numbers out of my ass, but I am confident they aren't far off. Anyway, the point is, it takes real effort to lead to premature wear on a butt simple motors like these.
