Author Topic: Clutchadjustment  (Read 1597 times)
Offline Terry Reedy
Clutchadjustment
« on: February 10, 2019, 06:38:54 AM »
Does anyone have a pic of the clutch push rod adjustment, I found the 75mm spec. But not a pic or diagram of the reference points ?
Re: Clutchadjustment
« Reply #1 on: February 10, 2019, 08:09:06 AM »
Offline Terry Reedy
« Reply #2 on: February 10, 2019, 09:01:13 AM »
thanks photoguzzi but that isnt what I had in mind, more like where do you measure the 75 mm
Offline Terry Reedy
« Reply #3 on: February 10, 2019, 09:03:53 AM »
I should mention I just installed a SD clutch kit so maybe the 75mm is not correct ?
Online pehayes
« Reply #4 on: February 10, 2019, 10:58:54 AM »
Sure would be nice to know what model we are discussing.
« Reply #5 on: February 10, 2019, 11:05:12 AM »
You measure from the flat case where clutch cable gets inserted. From that flat that the back cover gets mounted to--- to the center of the round inserted end on cable that is in the arm end.
There is a pic in the G5/SP1000 book.
Online pehayes
« Reply #6 on: February 10, 2019, 11:14:20 AM »
Here, I edited someone else's pic.
and I found this one in my files:
I don't think the dimension is all that critical.  What is important is that the lever does not 'bottom out' anywhere against the transmission casting or the frame when you pull fully on the handle and that the lever does not 'top out' anywhere against the frame when you fully release the handle.
« Reply #7 on: February 10, 2019, 11:21:42 AM »
Make sure the tension spring hasn't fallen out.
Offline Terry Reedy
« Reply #8 on: February 10, 2019, 11:58:45 AM »
Sorry, 03 Amulminum, double plate clutch and 75mm doesnt look at all correct
« Reply #9 on: February 10, 2019, 03:00:00 PM »
my memory is old but seem to think it was more like 30mm.. at least on a Convert but it's a pretty similar design.. don't make me dig for the source.
« Reply #10 on: February 10, 2019, 04:51:38 PM »
What Patrick sez. It's not rocket science..
Albert Einstein
« Reply #11 on: February 10, 2019, 05:34:37 PM »
Just measured my EV --47mm. I just lubed the cable yesterday.   original cable & clutch at 62Kmi , sorry no pic
