I'm stumped but maybe someone with electronics expertise can help.
Superbrightled.com sold me this 1157 replacement bulb, with separate functions for a running light and turn signal (for my T3 with 1157 "dual-filament" sockets in the front to accept them):
https://www.superbrightleds.com/moreinfo/tail-brake-turn/1157-led-bulb-dual-function-27-smd-led-tower-bay15d-bulb/2625/It is a really bright bulb with excellent differentiation between the amount of light produced in the running light and turn signal modes.
The problem is that the running light does not illuminate until the turn signal is cycled on and off one time. After that, the running light and turn signal modes both operate properly.
I tried the bulb with Superbright's "FL2-RED LED Bulb Electronic Flasher" and with an older electro-mechanical flasher (together with a shunting resistor). Both setups perform the same.
Superbright said they had just discovered the problem the day before I called, and said it is due to "the resistance being the wrong way" in the bulb itself. They offered to replace the bulb with a weaker one that I don't want.
My first question is
why the running light needs to be primed by the turn signal. How could the resistance be the "wrong way" (or was it "wrong direction")?
I guess one important factor may be that all 27 LED's operate for both the running light and turn signal functions, but at different intensities. They are not different circuits.
This could be a clue: If I turn the lights off with the light switch for as long as 60 seconds, the running lights come back on when I turn the switch back on -- no turn signal cycling is needed. However, if I turn the light switch and then the ignition switch off, and turn them back on again after 5 seconds, the running lights don't come back on. Except for this: cycling the light switch on and off a few times produces occasional short flashes of the running lights, followed by full illumination (without using the turn signals).
Aside from cycling each turn signal manually, I suppose I could set up an automatic turn signal bulb test circuit just to get the running lights working each time I turn on the lights. Is this the best bet? Do cars have such circuits, making this a non-problem for them? (How else could they sell this bulb?)
I am puzzled by the suggestion of a reversed resistance. Presumably this would mean a reversal of the LED's, since direction of resistance is not an issue in simple resistors. But the LED's wouldn't work if installed in reverse.
I need someone to shove me in the shallow water here. Does anyone see what's going on?
Moto
