On the mounting plate of 1984 850T distributor, how can you rotate the plate? The left plate is held by two screws but the right (base) cannot be rotated because of the screws that hold the mount for the wires. Instructions say to rotate the plate but it can only go so far. Not enough to line up with the static mark. Can anyone tell me what i'm doing wrong?Thanks
Some of my most frustrating moments with Guzzis, have been getting the timing right on a dual point tonti Guzzi. I eventually have always ended up installing a Dyna III ignition. Its nice to be able to set the timing perfectly, and then forget about it. With the points, I never really could tell if any running issues were caused by carburetion, or ignition.Rick.
Some of my most frustrating problems were the result of electronic ignitions going intermittent. I see the occasional Dyna issue crop up on this site. Device sometimes leaves rider looking for a trailer.Never had points / coil /condenser be anything but reliable. First set of points on my T3 passed the 50K mile mark before I changed them out of guilt.(Just converted my Ural to points after expensive lessons from PowerArc.) The confidence this simple system provides....
The actual procedure often proceeds as follows.Set gaps.Rotate distributor to set RH cylinder timing. Move point plate to set LH cylinder.When plate does not move sufficiently elongate slots with a file. When LH timing is still off "tweak" point gap to get correct LH timing.Then you are set until rubbing blocks wear.From then on I set timing with a light on a running engine by slightly loosening the point securing screw and using a screwdriver in the slot for moving the points base. Then snugging up the point anchor screws.This way there are no feeler gages fighting with bumps on the points and the timing is correct for each cylinder. Sort of like setting adjustable points with a "dwell tach".
Why wouldn't that procedure work on a Convert. Isn't the ignition the same as the 850 T3?
The Tractor Runs ! The Carb adjustments were off. Fine tuning timing next with timing light now that its running. Using the timing light, i should be looking for advanced marks at how many RPMs
My distributor does not have a pad for oil on point blocks. Is this normal?
it will be important to get the full advance timing correct, of course. By the way, the stock distributor does not produce a full 31° of advance, even though that is what the spec is in the manuals. [SNIP]
