Osmosis as I (think) I understand it, is the process by which a substance can pass through a membrane by chemical process or due to the relative sizes of the molecules..
Anyway.
Whether the fluid is under hydraulic pressure or ambient, the air has less density so will migrate upwards if unimpeded.
Good so far..!
But.
Remember we have the pedal depressed or lever pulled in, the communication port is “incommunicado” if you will, so the air will come into contact with a little thing called the master cylinder piston, which by all accounts can hold back fluid @ hydraulic pressures. So just to drag things back kicking and screaming to the point in question..
How in God’s green Earth is the air going to get past that piston ?
Not as long as your arse is pointing downward, unless you develop some anomaly in the system (leak), then you can pump ‘till your arse turns to parsley and you’ll not succeed.
So again, when using the “hang an anvil on the pedal” technique.
Please guys.
WHERE. DOES. THE. AIR. ESCAPE. TO..?
