Have them on my V7C. Easy installation. Better riding position and they're bloody beautiful too.
Funny you ask, I actually have a set on the way for my new stone, will give feedback as soon as I'm able
Wondering if anyone here has installed a set of these.https://www.satoracing.com/rearsets_motoguzziV7_III_17.htmIf so, did you find the installation straightforward and undemanding? Any irritating hooha involving the brake light switch or making the connection to the rear brake master cylinder? Finally, do you like them? Cheers.
I can see some lower bars as a possibility. Tarozzi have a few versions of adjustable clip ons, Tomaselli have adjustable ace-style bars, and Raask do the multi adjustable Laverda style bars (& in black, too). The adjustability makes it easier to set them up perfectly for comfort - no weight on the wrists, back & neck in a straight line = less fatigue at day's end.
Great minds ...... Photos, or it didn't happen.
I know this is a rearset thread, but I would like to second Malik's remarks about adjustable bars, particularly the Raask Laverda multi-adjustable bars (height/sweep/angle). These bars have been a revelation to me - for the first time in my long riding career I can enjoy bars configured exactly to the position most naturally comfortable for me: less adjustable bars force you to use a hand/arm/posture position set by the bars, but not the rider. Do not underestimate the the real benefits of being able to set the bars just as they feel best for you. If you elect to go with rear sets, it is important to set the bars in an optimal position so the increased load on your wrists and hands will not be a limiting factor. Multi-adjustable bars, IMO, are the only way to achieve this ergo nirvana. Setting the bars in your ideal, most comfortable position (this differs for every individual), IMO, takes priority over rear sets. Heartily suggest you try the Raask Laverda multi-adjustable bars, which bolt directly to the bar clamps on your upper triple. You will enjoy experimenting with positions, and you will be majorly pleased when you finally zero in on the satisfying position in which you were born to ride.
I’ve been running the Sato Rearsets in combination with a Motone Jota 2.0 bar on my V7III Stone for over 4,000 miles now, great combo, strongly recommended!The Satos are brilliant:A. Outstanding craftsmanship & engineering. Everything just fell right into place during installation.B. The function is fantastic. The bike shifts better than with the OEM footpegs, your feet are more inboard, the footpeg grip is better than OEM, and they are much more comfortable for a long day on the road while also improving the sense of control of the bike. C. The extensive adjustablility makes them worth every penny (there are cheaper options out there) as you can dial them in to your exact preference. The Jota 2.0 bar has two advantages over the other bars/clip-ons in my book:#1: Way more options to fine tune your ergos, and you can adjust them in just a few minutes.#2: It retains (or exceeds, depending on your setup) the width of the stock V7III Stone handlebars, meaning shoulder comfort & steering leverage are also retained. The Jota 2.0 does have disadvantages too:#1: The quality of the workmanship & customer service doesn’t necessarily match the price (I had to go find my own bolts to be able to actually safely assemble the bars, the finish scratches really easily)#2: They don’t have the mounting holes for the switchgear/controls, so you have to find your own solution for thatBut, on the bottom line, the combination of the Sato Rearsets and the Motone Jota 2.0 bar is a major winner in my book. Especially as I can take the ergos from sporty (bars forward & down, pegs back & up) to scrambler (bars up & back, pegs forward & down) in 5min, dialing in a position that fits me spot-on each time.If you'd like to hear more about them, and also see both of them on the bike, please feel free to check out my video reviews Sato Racing Rearsets: https://youtu.be/2G3Sb6VcItgMotone Jota 2.0 Handlebars: https://youtu.be/UmBZ5XnYx4I
Did your fairing come in matt black, or did you paint it?
I got them and the only 2 things I don't like is the pegs don't fold up and no rubber
Re the Jota-style bars.On the V7C I have the Raask version installed. They come either chromed or black painted. When they chrome them, the knuckles are also chromed, so the machined surfaces are no longer as fine as they would otherwise be. The black paint is not as thick as the chrome, so marginally better. Even so they still work, though I have had to keep a section of 10mm Allen key handy to tighten the screws that occasionally undo themselves.When I came across the Motone ones, I was attracted by the specs on the knuckles - they are bare, uncovered stainless (with an extra tooth). That's positive, but as TexMex says, their quality control is not the best. Mine arrived with a dusting of fine powdered rust on all the non-stainless bits, obvious on the insides of all 3 of the plastic bags that they came in. The knuckles were unaffected. Two of the four supplied screws were too short, and the advertised plugs for the screw caps were missing completely. Motone's customer service was very good, as good as can be expected from the other side of the globe, and likely to be even better in the UK. As did TexMex, for the price, I expected better.Do note that I was told that Motone plan making the whole bars from stainless at some time in the future.As well as Motone & Raask, tecbikeparts.com (another UK business) also make a version, and for half the price of the Motone. A mate has them on his GRiSO and is happy.The other "disadvantage" TexMex listed - the lack of holes to locate the switch blocks - I regard as a feature. As you keep adjusting the bars to find the correct position for you, the place where you want the switch blocks will change. I wrapped the bars with several layers of electrical tape, enough so the proud knob indents into the tape when clamped on. Only drill the hole & remove the tape when you've found your ideal position. That way you end up with only one hole each side. Also make sure the LHS block doesn't interfere with the clutch switch, especially on the 2TB bikes which need the clutch pulled in in order to start.As a side note (sic), I've found that the stock mirrors now actually work well - the low (and wide) bars position the mirrors so that you can see past your arms & shoulders. And I don't have to turn my head quite so much to check the rear view, as I did with bar ends. As bar ends, the CRG's, and especially the LS version are brilliant. All parts replaceable, all very well made, but even after years of use I couldn't get used to the far view effect of the convex lense. I don't get as good a view of the luggage, perhaps, but the view is just fine, as is the clearance while lane splitting.
Resurrecting an old thread. The V7 850 foot pegs / hangers look to be the same as the V7 III. Can anyone confirm? I'm looking for rearsets and Sato don't have for the V7 850 and responses I'm getting from the company don't currently fill me with hope that they will.
You might research parts drawings and see if the OEM part number is the same.If they aren't, I could take some measurements of my removed parts.Love the Sato racing rearsets. Best change for hip comfort I made.
