Author Topic: Loop Float Bowl Level  (Read 301 times)
« on: May 27, 2021, 04:29:11 PM »
Loop Float level.
I recall reading how to set the level of my Eldorado floats, I have been unable to find this tutorial.
I suspect the level of my left hand float bowl is too low, it runs rough until the bike is warm, the plug shows signs of lean running.
Thanks in advance for pointing me in the right direction.
Half a V9 Roamer
Re: Loop Float Bowl Level
« Reply #1 on: May 27, 2021, 05:13:01 PM »
You stick it on end with pivot down & float up, measure from edge of body to bottom of float as it's flipped towards the body. Check both sides and bend metal tab till perfect.  23.5-24.5mm
« Last Edit: May 27, 2021, 10:29:34 PM by Canuck750 »
« Reply #3 on: May 27, 2021, 11:56:31 PM »
Thank-you Gentlemen, that's exactly what I need.
Half a V9 Roamer
