Author Topic: Sport 1100 fuel filler cap  (Read 466 times)
Offline corsajim
« on: July 13, 2021, 12:26:58 PM »
Hi Guys, does anyone know where I can get a replacement filler cap or key and barrel. The key in mine keeps sticking and is very difficult to remove, I'm afraid it might get stuck permanently at some inconvenient time, I'm in the UK.
Thks
1100 Sport Carb
Laverda RGS Corsa
Offline Old Jock
Re: Sport 1100 fuel filler cap
« Reply #1 on: July 13, 2021, 12:52:00 PM »
I've got a Magni based Sporti, so I'm not sure if it's the same. Does yours look like this?
If so I sent the images to Oberon and they sent me an equivalent replacement
Oberon are in the UK, sure there will be other alternatives out there. The hard bit is identifying them
Not sure if that's any use
Offline corsajim
« Reply #2 on: July 13, 2021, 01:37:53 PM »
Thanks Jock, not quite the same, I've just emailed Oberon, so hopefully they might have something.
Much appreciated
« Last Edit: July 13, 2021, 01:41:01 PM by corsajim »
1100 Sport Carb
Laverda RGS Corsa
Offline Moparnut72
« Reply #3 on: July 13, 2021, 03:16:57 PM »
Have you tried graphite? Worked for me on my Audace.
kk
Mopar or Nocar
2023 V100 Marina
2019 V7lll Special
MGNOC #24053
Offline corsajim
« Reply #4 on: July 14, 2021, 08:35:07 AM »
Managed to get it working today. Dipped the key in copper grease, then used it in the lock a few times, now working perfectly. Used tiny amount of fuel resistant grease on the key afterwards to make sure its stays lubed. Thanks all for taking the time to read and reply.
1100 Sport Carb
Laverda RGS Corsa
