Hi Folks I picked up a Dyna III ignition for my 84 Cal II that I plan to install this weekend. My bike currently has the stock/original aluminum case coils. Can I keep using these coils with the new ignition, or should I change coils? recommendations? The bike runs perfect with the dual point setup, the only reason I am going with the Dyna is to eliminate points maintenance, and messing with the timing with the dual pointer. Thanks Rick.
In 35K miles I have had to replace 3 green 3 ohm dyna coils and one box. So that Dyna is crap to me. Essentially I have had almost as much trouble with Dyna as I have with Motoplat. Triple Jim lives close by and I gave him my original Motoplat dizzy and he has been working on making a CDI unit for Tonti's. At least I think that is what he is doing. I know he builds CDI units for Kaw triples and does a good business. He also has a CDI unit on his Mille with blue bosch coils. (5 ohm I believe) and points. I believe he is bench testing a new CDI unit for Tonti Guzzi's and is very satisfied with the results so far. Maybe he will read my post and tell the group what he is doing. I know he deliberately holds back on posting on WG about his work with Guzzi's because he doesn't want it to look like he is using his membership as a tool to sell his products. So I am bumping him. Hope he doesn't get mad at me for bringing this up.
Man, RedRider, that failure rate in 35K miles is unacceptable to me. I hope it was just bad ju ju or something weird. Ive read that if the dyna doesnt fail rather quickly, you are pretty much good to go, Ive also heard that the later units have improved over earlier units. I hope so....Rick.
