Do you mean it engages quickly, releasing the lever it goes from clutch pulled, to engaged without much clutch travel? Must be some sort of high performance clutch installed I'm thinking.. I don't know how to fix that, I'm just rehashing what you said without a purpose Edit, maybe the lever under the engine where the clutch cable attached is bent..
It never has much friction zone. It's rideable, but a PITA.There are no receipts, so I don't know what "kind" of clutch plates were installed. It came with a couple of boxes of spares, including what appears to be new clutch plates.
A recessed outer body is supposed to be an indication of worn throwout components
Sounds like my '71 Ambo "Barney" when it had Sureflex friction plates in it. Clutch like a light switch. Or new clutch plates...
I would go with the Dungeness and a fine Pinot Gris to complement that sauce!
I'll send along a good recipe for butter sauce .
MG Cycle sells a slightly longer outer body ( the clutch throw out bearing gizmo ). It's something like .040" longer than original. I put one in my Sport and it solved the issue I was having. And, it's only about $25.
Could this be a notched input shaft?
"I think" if there were a way to make the operating lever (part 12) straight and shorter, it would give more friction range to the hand lever in this case, but at cost of making the clutch lever harder to pull. Though, with the clutch cable adjustment being where it is, not sure it can be done. I'd say hit the machine shop and make something, and if it works, then you have the fix and a sellable product to go with those Sureflex clutches :-)
A little history. When I bought the "almost new" G5, the previous owner told me that when it got hot, the clutch was grabby. When I brought it home and put it up on the lift, I found the clutch actuating arm spring out of it's well, and trapped sideways. Smiled, figured I had this little problem solved, and started riding it. It was much better, but still didn't have much friction zone when hot.Now, I'm making progress. It never has much friction zone. It's rideable, but a PITA.Looking at the maintenance records, it had it's transmission rebuilt, new clutch, and apparently a new flywheel 12K miles ago.9-30-13 88027Rebuilt transmission with all new bearings and seals.New clutchNew rear main seal.Fly wheel.There are no receipts, so I don't know what "kind" of clutch plates were installed. It came with a couple of boxes of spares, including what appears to be new clutch plates.So, what am I looking at? The throwout bearing gizmo is recessed about .030-.040" The clutch doesn't slip or drag. Could this be a notched input shaft? The clutch actuating arm has "plenty" of clearance to the case. TIA
Chuck, The bottom line is if you continue to ride it with abrupt engagement it will destroy every splined connection in the drivetrain. $$$$Don't delay. Hunter
TWENTY FIVE DOLLARS?? <biting off corncob pipe stem and snapping suspenders> I could make one for nothing..
Everytime you do this I get a visual and almost pee my pants laughing! I'll bet you really do chew on a corncob pipe and snap your (wide) suspenders!
Chuck, try a spacer between the clutch lever perch and the handlebar. I made one about 3/8" or 1/4" thick, half moon shaped to move the lever away from the bar. It gives it more throw so you can have plenty of free play and still get good plate separation . It only works on split clamp style perch, of course and the fit has to be good or you will break the clamp when you tighten it. Don't ask how I found that out. I found this trick when trying to get Ram clutches to last. I liked it so I use it on regular clutches where it works well. I also recommend a ClickAdjust lever unless you have large hands.http://www.mgcycle.com/index.php?main_page=product_info&cPath=38&products_id=1209 http://www.mgcycle.com/index.php?main_page=product_info&cPath=38&products_id=1215uhttps://www.lowbrowcustoms.com/british-standard-handlebar-shims-reducers-run-7-8-inch-handlebars-with-1-inch-risers-or-p-clamps.html?gclid=EAIaIQobChMIwb6Ezamp4wIVB7XACh3BRgwCEAQYCCABEgKUO_D_BwE Similar to this except thicker in th middle and tapered to the edges
