And they went with a counter balancer! Please, that was one of the cooler things I would give HD and Guzzi credit for, not wussying out and caving to timed. But I do understand, as articles state, they are after conquest sales.
OK, 8 valves, but what about the RPMs? if it doesn't rev, then you're talking marginal power differences vs the standard bike. Perhaps better emissions and gas mileage, smoother, stronger torque?
motorcycledaily.com posted a link (http://www.motorcycledaily.com/wp-content/uploads/2016/08/2017-mc-ctrr.xls) to an EPA spreadsheet that lists certification data for 2017 motorcycles.In the spreadsheet, the rpm is listed under a column labeled EDV Rated RPM. EDV stands for "emission data vehicle." Not sure if that is the same as peak hp rpm. 4K seems kind of low for peak hp rpm of a Twin Cam.In the spreadsheet, the XG500 and the V-Rod are listed as not using catalysts.Per the spreadsheet:Model: hp/rpm XG500: 36.3/7,250XG750: 59/8,000XL883: 53.6/6,000XL1200: 67/5,500V-Rod: 122-127/8,250Twin-Cam 103: 80.5/4,000Twin-Cam 110: 87.2/4,000Milwaukee-Eight 107: 93/5,020Milwaukee-Eight 114: 101/5,020
Without a good suspension system, a newer engine to go slow won't be worth the extra money.
OK if this engine is making 107-114 HP that's pretty salty. Their previous big blocks made something like 70HP at the tire. That's a hefty increase or 50%!I'll be the first to admit that's impressive performance. It should be more than enough to keep up with the Cal 1400 and spank most Moto Guzzis (my V11 Sport included). It looks like we'll have the first performance oriented big Harley. Now they'll need to build the rest of the bike to handle it.
93 and 101 hp respectively, probably at crank and a few hp lost by rear wheel, but not much based on other numbers on that chart.Keep in mind these are still not supposed to be high hp motors, they are still going to be tuned for torque, but they should get out of their own way nicely.
Highly unlikely, upper RPM's is still around 5k. I bet RWHP will not be more than 75.
I wounder if they will do the same to a new Sportster motor?
Rumor has it the new "wart" head will be a unit construction design . Dusty
Are you talking the M8 (it's not) or am I missing the joke
No, not unlikely at all, comparing the other motors in the test to various rwhp numbers from sources like MCN, cycle world, motorcyclist, etc. over the years suggests those numbers are probably not far from actual rwhp.
The 107 and 114 is the cubic inches not the HP.
Interesting, but a Harley (other than the VRod/Street) with VALVE ADJUSTMENTS? Hmmmm...
Hope they didn't get pointers from Guzzi.
Where have you been Nick ? Dusty
An HD buddy of mine who got some sort of notice about this said it's going to be a hydro.. This info not vetted at all.
