P0611-Fuel Injector Control Module Performance -- **This lives continuously on the Guzzi MIU ECU. Check to see if you have an over-charging scenario : 15V+ at idle - replace voltage regulator immediately**
P0653 - ECU has detected a high voltage condition from the coil or related.
I recommend you reflash the map again, including relearning the throttle.
If you are still getting P0653, you may have a bad sensor. Check engine & air temp in GuzziDiag make sense. That is, with a cold engine, engine and air temp should be close or equal.
