I must be the only one who likes the original Lucas generatorI run heated vest and gloves, its able to manage better than the Bosch Alternator on my California II
Lucas? Loops only ever came with Marelli or Bosch. Guisto: check out this chart: http://thisoldtractor.com/moto_guzzi_loopframe_electricity_usage_by_component.html How do you plan to use the spotlights - on all of the time or just when it's dark or conditions warrant? The original generator can keep up with either 35s or 55s if everything is in good order. You might consider changing the bulbs/sealed beams to 35 watt if you're going to run them all of the time. Or, if you don't mind the "modern" looks, these are very effective on my Convert and light the road up amazingly well while drawing much less:https://www.amazon.com/gp/product/B06X19TGND/ref=oh_aui_detailpage_o01_s01?ie=UTF8&psc=1
Only game in town for a full kit is Scrambler Cycle. Field/Nolan gone unless you can find one that’s been squirreled away like I did.
Hey Charlie,I certainly don't mind at all if they work better at night. Was hoping to wire for additional night lights...don't need them on all the time.any ideas on how to wire ? Thanks for the help...hoping you are still able to get out on those WV twisties.
Oh mine has a Lucas Starter with the solenoid on the bottom, I just assumed the Genny was from the same source.
?? If yours has a Lucas starter, then that's the first I've ever heard of on a Loop. Marelli and Bosch again. The only Lucas starters I've seen on Guzzi as a whole were on small-blocks.
I usually fish another power lead directly from the battery (with an inline fuse) up through the original main harness sheathing to a toggle switch such as this: https://www.mcmaster.com/7343K711 and then directly to the spotlights. Until the "brine" that was sprayed on the road Wednesday is washed away, my bikes are parked.
You're right again Bosch and Bosch I had to go take a look, it does have Lucas blinkers though, I suppose those were added by the PO.Could I be mixed up with the Lario I had for a while I'm sure I had a Lucas starter?
That is the obvious and period correct way to do it, but the Eldo I'm working on has a nice headlight bucket and instrument panel. I'll not be the one to drill a hole in either. Ordered one of theseand will use it to trigger a relay.
I always wanted to ask why so many people swapped to alternators on their Loops, when most I've seen are running stock lighting. I rode a '72 Eldo and then a '74 for a long time and never had any issue charging the battery, starting, or running the lights at night. if not running extra lights or ports for heated clothing, why is an alt "upgrade" necessary?And if running low-draw LED or halogen aux lights, again, is the alt upgrade necessary?
^this and be done.-AJ
Thanks for the input.it looks like I'll wire the spots to a new switch...."thanks for link Charlie" and right to the battery fused and see how she does.Cheers....and Happy Thanksgiving!!
Chuck, Link for this switch? Thanks
Mine's cheaper.. works fine. (with a relay, of course.) https://www.amazon.com/gp/product/B06XZGBDBF/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
Chuck which relay? and a quick wiring diagram with relay pleaseThanks
I bought an alternator from the local auto parts store and made a bracket. Scrambler Cycles isn't he only option.
