Ummm. That's not a fork brace you've left for your self. Regardless of how tight you make those 4 bolts the set-up is very poor.The casting you took off was essential to maintaining the fork tubes in parallel at all times. (bumps, braking, steering, etc.). IOW: you're expecting the front axle & bearings to do that work. They cannot. They were never designed to bear that kind of twisting load. It's very dangerous, as it is. Put the brace back on the bike, with or w/out the fender. The FORK BRACE more than a fender support. Do not ride the bike the way it is. R3~
