Why not splice in an LED berry and be forever done with bulb problems (and pick up a few more watts for the headlight)?
BTW, there is a secondary issue compounded by the plastic reflectors and cheap sockets. The hand brake switch is activated by a tiny ball bearing which passes through the brake handle perch. It gets dirty and sticky and my hold the brake light ON 100% of the time. If so, the bulb heat will soon melt your reflectors out of shape. Good idea to inspect that switch and its drive ball and keep it clean.Patrick HayesFremont CA
That's very interesting. Is the light as bright as the incandescent lamp?
If it is a white LED, you probably do NOT want it.How many watts is it?
Why not white?
crap George! you could have bought a good cigar for $12.99 instead. get your priorities straight.
