Instrument cluster configurationIn the "TOTAL ODOMETER (ODOMETER)" mode, long press the "MODE" button to access advanced functions including:1) Gear shift threshold (SET GEAR SHIFT)2) Change odometer unit of measurement (SELECT UNIT (mi/Km))3) Change mileage gages unit of measurement (SELECT UNIT (US mpg - IMP mpg - L/100 - Km/L))4) Change thermometer unit of measurement (SET UNIT °F - °C)…Select unit (mi/Km) "Change odometer unit of measurement"Within this function you can change the unit of measurement to "mi or Km" by short pressing the "MODE" button. The change affects all the instrument panel settings which use these units of measurement.Select unit (US mpg - IMP mpg - L/100 - Km/L) "Change mileage gages unit of measurement”Within this function you can change the unit of measurement to "US mpg - IMP mpg - L/100 - Km/L" by short pressing the "MODE" button. The change affects all the instrument panel settings which use these units of measurement.
