You've been probed...
I am just guessing but your Guzzi might be an older one, still if you haven't remove the oil pan you might still be getting metal pieces from the manufacturing process??
I found metal flakes when I did the second oil change 6K (first done by dealer). When I changed the engine oil the third time I installed a extender plate in the oil pan. In the bottom of the oil pan I found some machining left overs, tiny spring looking things and some chips. Sloppy job in manufacturing the 2015 V7. My first oil change gave me some worries (metal flakes) but the forum gave me some comfort. I am just guessing but your Guzzi might be an older one, still if you haven't remove the oil pan you might still be getting metal pieces from the manufacturing process??
If it was from a gear tooth- that would be "case crushing". Essentially, the hardened outer case would be flaking off the tooth. This never ends well. Once the ductile core of the tooth is exposed, the tooth will fracture and break off. The broken teeth are not subtle and should fall to the bottom of the pan.Case crushing can be a defective (too thick) hardened case- or it can be related to a violent event (abrupt stoppage of the drive train). Typically, gear teeth will wear with a pattern of tiny micropits on the pressure face of the teeth. They extend up the flank of a tooth in a V pattern. This will not produce flakes like what you see here. If you are suitably worried- drop the pan and see what you find. I would probably add some lighter solvent to the oil in the bottom of the pan to thin the oil out, then drain it all onto a paper towel to act as filter paper.
I blame it on the Welsh...
I found this bad boy in the oil pan of the Mighty Scura the first time I changed the oil. That was a long time ago.. Pete said it was a spare bit, IIRC..1-155 by Charles Stottlemyer, on Flickr
