Disassembing my transmission after the broken shifter spring episode and there is a washer between the transmission speedometer body and the little pinion gear and none on the end where the pinion rides in the aluminum hole. Is there not supposed to be one one each side of the little pinion? Very strange as I bought this thing new and have never had the speedo drive out of it's hole before. There is some damage to the ball cage so must have been something floating around in there. No sign of any washer now though. The way it is made I can see that it would be captured on the one side of the bearing if it were to fall off. Just want to make sure there really are supposed to be two washers before I go about ordering up some parts
