Author Topic: Stelvio rear wheel assy  (Read 1350 times)
Offline AH Fan
« on: November 20, 2017, 10:23:32 PM »
Anyone know if a 2015 griso rear wheel and tire will fit a 2015 Stelvio rear?
Ciao
Re: Stelvio rear wheel assy
« Reply #1 on: November 20, 2017, 10:37:39 PM »
It will, but tyre choice will be limited as its a wider rim. If you want alloy wheels why not just buy a set of the factory wheels? Correct sizes and remarkably cheap, about $500 the pair from TLM.
http://www.tlm.nl/webshop/en/wheelset-stelvio-all-types-new-tl897629-631-moto-guzzi
Offline AH Fan
« Reply #2 on: November 20, 2017, 11:01:24 PM »
Thx for that Pete............ thought a guy might be able to get a little more mileage out of the wider rubber.
My Norge will out run the Stelvios rear rubber in stock format any time any where.
Ciao
Offline Xlratr
« Reply #3 on: November 21, 2017, 12:18:52 AM »
Stelvio has an ABS ring mounted.  Will that attach to the Griso wheel Pete?
I changed to cast wheels but can't remember if the disc and ABS ring share the same mounting points.
Sent from my iPhone using Tapatalk Pro
« Last Edit: November 21, 2017, 12:24:01 AM by Xlratr »
« Reply #4 on: November 21, 2017, 12:52:13 AM »
The brake swaps, ipso-facto the ring will fit. After all it's the same wheels fitted to Brevas, Sports and Norges.....
Offline Xlratr
« Reply #5 on: November 21, 2017, 04:53:38 PM »
I just had a look at my rear spoked wheel. The ABS ring is mounted to a separate set of holes. If the wheel on the Griso has those holes then the conversion should be easy. But I recall reading somewhere that somebody had to drill and tap those holes to make it work.
Anyway, worth checking.
Offline AH Fan
« Reply #6 on: November 21, 2017, 05:34:02 PM »
Hi all thx for the responses.
I would like to use a spoked wheel for the rear and because I'm on this side of the pond not sure if there are any differences?
Anyway I know the earlier version of the stelvio with spokes had a wider rear........... maybe that's the way to go( probably a little harder to find is all )
Thoughts
Ciao
Offline guzzi ride
« Reply #7 on: November 21, 2017, 07:59:26 PM »
As Pete said all of the Griso,breva 1100, Norge and Stelvio rear wheels will interchenge rear rotor,abs ring also.
Here's my 08 Norge with 1st gen. Stelvio rear wheel and a Griso front
image upload
Offline AH Fan
« Reply #8 on: November 22, 2017, 02:33:05 AM »
Very good............ that's what I was looking for.
thx all.
