Let me see if I understand this correctly. You switch the key on, the dash does its little disco, then when you press the start button, the dash goes blank, then restarts? If you keep your finger on the button, the engine cranks and fires?
Check battery and ground connectors.
Thanks. Will do. I already checked the battery terminals. I'm guessing you mean the battery to ground connection - which I haven't checked.
