Author Topic: New tires $44ea  (Read 395 times)
Online Perazzimx14
New tires $44ea
« on: May 25, 2022, 06:05:21 PM »
It was time for some new tars as the old ones were almost a decade old and getting hairline cracks. Shopped around and finally found what I was looking for and only $44ea shipping included.
Spent about an hour changing them out and all is well. If the weather holds, I take them for a test ride tomorrow and see how they perform.
It's the ones who've cracked that the light shines through!
Offline sdcr
Re: New tires $44ea
« Reply #1 on: May 25, 2022, 06:18:38 PM »
Looks like a rain tire. Just in case the grass is wet?    :thumb:
2000 BMW R1100 RS
1983 BMW R100 S
2009 Jaguar XK
Offline larrys
Re: New tires $44ea
« Reply #2 on: May 26, 2022, 07:20:50 AM »
Where did you find them? My Cub Cadet 2185 still has the original skins, and they're about done.
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
Offline s1120
Re: New tires $44ea
« Reply #3 on: May 26, 2022, 07:31:04 AM »
Ive used those before, and had good luck with them. A good mix between a mild "not mess up the lawn" but still good grip that you dont get stuck, or skid around every turn.
Paul B
Wildgoose Chase Moto Guzzi
Re: New tires $44ea
Online Perazzimx14
Re: New tires $44ea
« Reply #4 on: May 26, 2022, 01:55:37 PM »
I was able to try out the new tars. At first I was very careful because of the mold release compound so I too it slow the first few passes. The tars really gripped well and seem to heat up quickly. I even ran over a dog turd and these tars stayed straight and true worth no slippage. Once the tar's had a few laps on them I pooshed them a little harder in the turns and was able to knock off the chicken strips. I found that even in off camber 180 degree U-turns at the property line these tar's stuck like glue and held the corner with amazing precision. They are very confidence insuring. I did find that at top near speed (3-1/2 mph) there is a slight vibration but that might have been a piece of turd still stuck in the thread throwing off the balance Might remove the wheels and have them computer balanced if the problem persists. All in all for $88 + tax I'm satisfied and would recommend these to anyone.  :thumb:
Online Tony F
Re: New tires $44ea
« Reply #5 on: May 26, 2022, 05:00:28 PM »
What tar pressure are you running?
Offline TOMB
Re: New tires $44ea
« Reply #6 on: May 26, 2022, 05:17:44 PM »
12x10.50x12?
Where did you buy those for that price?
 I need some new tires for my tractor and those look like the tires that I want in my
 thanks for your input.
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Online Perazzimx14
Re: New tires $44ea
« Reply #7 on: May 26, 2022, 06:45:32 PM »
First and foremost, let me thank you for recognizing the difference between tars and tires. Currently running 22psi but once summer sets in I'll back it down to 20.12psi to accommodate for the heat index.
12x10.50x12?
TOMB
I got the tars from a French supplier Le' Home Depot'
Harper's Moto Guzzi : Go Ride , Break Parts, Call me!
Harper's Moto Guzzi. Where we still answer the phone, use the highest quality parts, and also do Transmission, rear drive, and carb rebuilds fast. Call us at 816.697.3411 and get your problems resolved.
http://www.harpermoto.com
