Was it burning/using oil? You saw deposits on the valves, and attributed that to bad valve oil seals, but didn't mention oil consumption.
The extra noise you are hearing, could it just be reflected noise off of the sidecar? When I had mine, I can remember it sounding "different" from solo form.
Check the crankshaft end play by prying the flywheel aft and using the clutch lever to move it forward. If it has a timing hole in the bellhousing it’ll be easier but you can pull the alternator cover to visually see the play. if it’s more than a millimeter, it’s time to look at the thrust washers on the crank.
Thank you to both you and Pete for sharing this information along. I wonder if there’s a way to easily see if the seals have gone bad? Perhaps I’m making my exhaust clearance just a hair too tight, keeping the valve open slightly? (Exhaust is supposed to be 0.20 mm)Also—I just found this wear mark on my exhaust-side rocker arm during a second look over. Is this a factory wear mark, or is the stem or rocker somehow slipping?Indeed I will!That mark looks like the underside of the rocker is hitting the valve retainer. It’s the exhaust valve, there’s another smaller mark on the intake . That would make noise as well as causing the valve to leak until it self clearanced itself.
Have you checked the timing marks for correctness, then gone ahead and put on timing light on it see if it’s too advanced ?
IIRC there are no timing marks on the modern smallblocks. When we adjust valves we use a TDC finder of some sort and that's it.
Any updates? I'm thinking I may have the same issue to resolve but no one knows the cause of the sound.
Just a wild-ass thought, but could it be a flat lobe on the camshaft?
Certainly worth the thought, I suppose. How would I even check that without dissembling the motor completely? Only way I can think is removing one of the cylinders (once again) and sticking a borescope down in and faced upward to view the cam from below?
Couldn't you just pop the valve covers off, and as you rotate crankshaft, indicate the amount of movement of the Rocker arm of the valve in question (say, intake valve), and compare readings to arm movement on opposite cylinder?
