The bike is showing a 'Service' warning. This means the dash is recognising an active problem with one of the vital components of the engine management system. This is why the vehicle has an On Board Diagnostic system and why the dash stores and memorises errors. You can speculate until you're blue in the tits! Or you can simply check the codes and find out what the problem is.Pete
From another post, not mine:"Flip the Trip 1, Trip 2, Mode selector on the left handlebar to Mode. Scroll to diagnostics. Enter the access code(28315) and check your ECU and dash error list. "Shouldn't take more than a minute or so.
99% of what gets posted on WG is speculation.
Hate to be the bearer of potentially bad news but my 2007 Norge had the exact same problem (turn the key, guage sweep, red triangle, bike cranks strong but does not fire). I spent a lot of time on here and at the dealer. Down loaded the codes but none of them led to anything (don't remember what they were.) In my case, the bike would eventually start. I would just have to turn the key off and wait awhile and try again. It always started eventually (but not always on the same day!).I tried the startus interuptus fix, new battery, new clutch switch (that was one of the codes), and a lot of head scratching, but it never got fixed. Just became more frequent. Eventually traded it in to the Suzuki dealer for my vStrom.
I had this problem with my 07 Norge but it only happened when it was hot outside, in cold weather it wasn't a problem and if it sat for ten minutes or so it would start. I forgot the code it showed, by it was the consensus of this group that it was the connection to the bike computer. I still have not hunted for the connector (lazy) but from what other's have said this is a dig. Might this be your problem? Without looking at those codes it is just a guess.
Discounting any codes that may be showing, this sounds like the vapor lock that used to plague the V11s, The fuel in the pump vaporizes and the pump can't get a grip on the gas to move it along until everything cools down'The gas won't pass through the injectors like liquid as anyone with diesel experience will tell you.What codes are you getting and what do they mean?
FWIW, it sounds like a fuel issue to me, too, for whatever reason.
Roy, This happened quite awhile ago,so I don't remember what came up. I haven't had a problem since it's gotten cool out but it only happened after I parked the bike and it sat for awhile, like a half hour. If I attempted to start the bike right after it was parked, it would start right up. I just assumed it was some expansion/corrosion issue with the plug on the computer.
I believe this was how it showed up in the V11 Sport, it takes time for the heat to get through the rubber hose and vaporize the fuel like 10 minutes after filling up, it will start again straight away because the fuel hasn't had time to get hot. I am only going from hearsay.I think this only happens in hot climates, never happened with mine in Vancouver but the PO had wrapped a bunch of reflecting tape around the hoses.The V11 pump is under the tank, I think the Norge is in tank where you would expect it to keep cool but vapor locks are quite strange.I'm not saying that is the cause but it might be worth keeping in mind.
Try this:If your EVAP canister system is still installed, the next time you ride the bike for a few minutes; stop and remove the gas cap. Make sure your helmet is off so you can hear well and see if you hear a whooshing sound when you remove the gas cap. If so, your line to the canister is plugged, or the line is plugged. Also, if the fuel overflow line is plugged from gunk it can do this. I had this happen on a Vespa scooter that my wife used to own (several times). It had me totally baffled for a couple of weeks because it would start after it sat for a couple of days and then do it again. I finally associated it with her filling the tank and went from there. I removed the evap system and it never did it again. I later read on a Vespa forum where this had happened to a lot of people.It may NOT be your specific problem but it's worth checking out. BTW, this can happen if you overfill the gas tank and too much fuel accumulates in the charcoal canister causing an air blockage, etc etc.
Was the Vespa fuel injected?Did the Vespa show an error code?Maybe, I don't know Vespas.
ALSO; I re-read all the posts in this thread and a couple of people asked if you can hear the fuel pump priming when you first turn the key to "on". I couldn't find a post from you where you answered this question.So, when the engine wouldn't fire, di you hear the pump for several seconds when you first turned the key to "on"?A faulty fuel pump can work fine until the pump gets hot and then it would not work until it cooled down. May not be your problem but it's another thing to check.
Can't be vapor lock. The pump is in the tank submerged in liquid. Everything downstream is pressurized fuel that won't vaporize. And the ECU wouldn't have a clue and throw a code like that.
Did you pull up the service codes?
I beg to differ, gasoline is made up of a witches brew of hydrocarbons, some more volatile than others.Just reading through this Chevron document about gasoline volatility, I don't understand half of what it's talking about, perhaps someone else here can scan through and translate it, in particular the first few pages on vapor lockhttp://www.chevron.com/documents/pdf/MotorGasTechReview.pdfI may be cynical but why would the petroleum companies worry about making gas to suit just a few motorbikesYou may be right about vapor lock but something causes the V11s to be hard starters on a hot day, the bikes probably run a lot hotter than a car, my theory is one of the volatile components flashes off displacing the liquid in the pump.Some of the posters claim the Norge has trouble on a hot day, what temperature would be possible under the tank?I agree it's hard to figure what error code it could generate but no one has posted those yet.
