So installed new fuse, pull up side stand, turn on the key, wait until the fuel pump stops, hit the starter, all lights/headlight on, N (green) is on, click high beam, blue light comes on, low fuel light lit. Okay all is looking good! Then I pull in clutch lever, all lights go out again!
This is a bit of a puzzle, the drawing doesn't show a switch on the clutch lever.Patrick, I seem to recall there is an interlock on the clutch but maybe I have my models mixed.
I'm starting to think about a bogus grounding.Patrick HayesFremont CA
Fuel pump is running. (a secondary question about the sound the fuel pump makes is very strange - maybe that's the way they sound. Hard to describe)...This may be of interest - once cranked, the low fuel yellow light is on. I rode down to the Sinclair Station and filled up. The low fuel light is still on.
I think the fried sensor results in a light always ON rather than a light that never comes on.
*Carefully check the two bundles of wires at the left rear of tank. Make sure it is red to red on the one bundle, then the other bundle should also be correct. Am I following you correctly?
