Recently, the shifter on my 2004 EV has been sticking. Not the linkage from what I can tell. Oddly, only when shifting into third, and only when accelerating. Never heard of such a thing, and I'm not sure I understand how it could do it. Basically, as I accelerate through the gears, when I go into third, the lever sticks. I can either press the lever and force it, so I can shift to fourth, or roll off the throttle for a second and it will spring back by itself as it should. I have had it happen when downshifting into third and accelerating.Has anyone ever encountered such a thing?
Symptoms are similar to what I experienced on a 96 Cali 1100 many years ago. I appreciate that you have replaced the input bearing, but this is what failed on my machine.Perhaps you will have to remove the gearbox to get a better idea of what's goling on. I appreciate that this is not a small task, but winter is approaching and probably the best time to do it. Good luck.
About 6 months ago I switched to Redline Heavy Duty, to quiet down a noisy fifth gear.
I know we're talking apples and oranges, but on the V11S pre selector, the return spring is so heavy that it puts a divot in the shift pawl. That can cause sticking on down shifts.
. And how can can you use 5th with a sidecar?! I never use 5th! unless seriously breaking the law
I have heard some folks say that some Redline lubricants have a tendency to either centrifuge-out or drop out some components or additives from the lubricant package. Though many sing praises for Redline lubricants - it gives me just a bit of pause.
nobody said anything about a sidecar.
The 5 speed in my CX100 had always worked perfect. The last time I changed gear & diff fluids,,, the moly I added to the diff oil, had been marketed as an excellent manual transmission additive, so after I finished with the diff, I thought it would be a good idea to dump some of the left over gear oil/moly mix into my transmission. Shortly thereafter, I did a sloppy coasting downshift from 5th,,, the tranny locked in 5th and I had to do some major mcgyvering to get it out of 5th and ended up in a false neutral from hell. The tranny seemed to settle down after major dicking around with it. The tranny then worked fine, not noisy at all,,, but I kept a close eye on things and found lots of metal scarf in 2 gear oil changes. Apparently Moly (not sure what is in Heavy Red Shock oil) is great for gears but bearings hate the stuff,,, I think my thrust bearing is gone inside, but just a wag, fwiw. Kelly
FWIWI've been running red line in my CX(trans) for 'bout 20K miles and it has made the trans shift better and its less noisy!Slippery stuff indeed. Think I'll "stick" with it.:-)
