Like the end can. Where did you acquire that? Did you have to re-map?Cheers
It's a Staintune can, I wanted something simple as I'm not a fan of the Italian aftermarket can looks (sad I know). GPR cheapy cans I didn't like the pop rivets and makers badge visible so Staintune it was, after my old small block it's a bit quiet even with db killer removed but I'm sure it'll bed in.Bike has a Rexxer tune but not 100% happy as it idles high imo and a little strange both when warm. As far as I know a tune is not required.
When you say it 'Idles high' do you mean sometimes the idle hangs up around 2,000 RPM or are you just worried that it's normal idle speed is too high? If the latter don't do anything. The idle speed should be 1,200-1,250. It's hard coded into the ECU and is stepper controlled. You can't change it without screwing everything up, badly!Pete
The 1200ish. Wow didn't expect an idle that high. Thanks for clarifying.I thought it was a symptom along with an occasional drop of one cylinder only when warm at idle. Idles fine for 20-30 secs then *rock* one cylinder doesn't seem to fire, idles fine for another 20secs then *rock*... Not regular intervals though.Sent from my Nexus 6P using Tapatalk
Oh dear. That's a classic symptom of poorly balanced throttle bodies or worse, some mug having messed with either the throttle stop screw or linkage rod.Are both the air bleeds open? Has anybody tried to 'Lower' the idle by winding out the throttle stop screw, (Is the paint on it still intact?) has your bike ever had a proper tune up? ie, have the valves been set, the TB's balanced correctly and the TPS recalibrated?Is the Rexxer map just their 'Off the shelf' offering? They're pretty crude. Add in an inadequate tune and it's not surprising it's spitting back through a throttle body, (That's what the hesitation and 'Chuff' is that you're hearing.)Sounds to me like it's been messed about with by someone who doesn't know what they're doing.....Pete
Just a better shot...Sent from my Nexus 6P using Tapatalk
:1: on the rear. A sweet single sided rear end then it is covered by the big can
Beautiful bike Pug. It'd be great if you could see the wheel a bit better though !
