Author Topic: For the pilots - Circular Runways?  (Read 5842 times)
Re: For the pilots - Circular Runways?
« Reply #60 on: March 18, 2017, 11:44:34 AM »
D
A Cessna 335 is the unpressurized version of the Cessna 340...a twin engine aircraft, soooo.. must have been a pretty bad situation to have had an off airport landing due to an engine failure or was some other reason..curious.
just say'in
Will they maintain height in a rate one turn on one engine if you don't turn into the "dead" one ?
kirby1923
« Reply #61 on: March 18, 2017, 11:54:45 AM »
Yes if you get the bad engine feathered it will fly quite nicely on one in either direction or even a roll.
« Last Edit: March 18, 2017, 11:59:01 AM by kirby1923 »
« Reply #62 on: March 18, 2017, 12:02:41 PM »
Than you, I'm not twin rated, but I do have over 2,000 powerless landings!
Offline Testarossa
    • Skiing History
« Reply #63 on: March 18, 2017, 03:21:16 PM »
'Could there have been a better way for him to massage his own ego ? Just for us mortals, what would you hard ass have done if there was someone on the taxi way blocking your "glider".
I don't think it was his ego he was massaging. He just wanted to show me I could do it. Mind you, he knew there was no traffic on the ground or in the air, and the wind was calm. And he'd also seen me land a sailplane with precision.
« Last Edit: March 18, 2017, 10:28:34 PM by Testarossa »
70 Triumph TR6R, 74 850T, 74 Yamaha TA125, 89 Mille GT, 99 F650, 2013 Yamaha XT250
« Reply #64 on: March 18, 2017, 03:55:45 PM »
As for the 335:  It won't climb on one engine above 5000 feet. I don't know of a piston twin that can. At 1000 feet on a 90 degree F day, density altitude is 5500 feet. Faced with rising ground he may have had no alternative to a controlled forced landing. I can also envision situations where both engines failed: A fuel system failure (or misfueling with Jet A). My instrument instructor killed himself and passengers, in a light twin, taking off from Truckee (5900 MSL) into an ice fog. Both props iced up on the climb out and he augered into a back yard half a mile from the airport.
Ok maybe it wasn't his ego he was massaging, was he flying with one hand ? I'm not commenting at all on why the crash ended fatally. Period. The guys paid with their lives. I've been a flight instructor for over ten years and I know that simulating an emergency while not exposing yourself to that emergency is where the real skill comes in, not some mis placed,  mis timed act of bravado that is thinly disguised as "training". Also Donald Duck can be taught to land a sailplane accurately since the glide performance can vary from 50/1 with zero air brake, and 15/1 or so with full brake. An overshoot dead stick in your Cessna can be dealt with to a degree with side slip, but an undershoot is a problem because you've no brake to reduce to extend your glide. If he wants to play games, he ought'a do it on his own or not at all. What would he have done if you'd gone up again solo and done the same thing ? Berated you or said to HIS boss, "I taught him that" he's a great pilot... BS.
« Last Edit: March 18, 2017, 03:59:34 PM by Huzo »
Offline acogoff
« Reply #65 on: March 18, 2017, 04:12:16 PM »
     Please be aware that if the offending engine has either a broken spring inside the prop or an oil control problem and the prop won't feather you are in very serious trouble.
Marshall County Minnesota USA
Offline Testarossa
    • Skiing History
« Reply #66 on: March 18, 2017, 04:12:49 PM »
Kirby, I stand corrected.
kirby1923
« Reply #67 on: March 18, 2017, 04:22:21 PM »
Hey Seth, its all good!!
I debated about the post and decided to remove it!
Hope your enjoying your new digs!
Hello to Gail!!
« Last Edit: March 18, 2017, 04:24:19 PM by kirby1923 »
kirby1923
« Reply #68 on: March 18, 2017, 04:27:21 PM »
Could be an electric prop..no?
Hey anytime you leave the ground in one of these machines the potential for disaster is there.
Thanks for the warning though.
Offline Nic in Western NYS
« Reply #69 on: March 19, 2017, 12:32:58 PM »
Don't know if this was the article Lannis was referencing, but this showed up in my facebook feed today:
http://www.bbc.com/news/magazine-39284294
http://www.endlessrunway-project.eu/
Doesn't seem sensible to me but..
'04 Ducati ST4sABS
« Reply #70 on: March 19, 2017, 02:44:10 PM »
It is the same.   I just didn't want to admit that I'd been reading the BBC ...  :embarrassed:
« Reply #71 on: March 19, 2017, 06:51:27 PM »
Ahem! You are going to ruin your image, if you're not careful..  :smiley: :boozing:
(I try to listen to both sides, too.) I remember thinking when I was still in grade school.. " It must be nice to know *all the answers in black and white*.."
Sorry for the political content, Dusty.. but I think it's pretty middle of the road.  :smiley:
Albert Einstein
