If you are still running the original shock Spring I'm not surprised. It was woefully inadequate even for solo work. Remember the bolt is essentially made to work in tension, not in shear. If the shock keeps topping out and hammering the bolt in shear I'm not surprised it has failed. If the cause wasn't addressed the first time history will repeat.Pete
Shit !Is that on your '07 Norge JD? That's gotta' be a bugger!Do you reckon you should get a higher grade aircraft bolt or equivalent ? Mine'll be getting pulled down upon return to Oz, and I'll be checking that out quick sticks.It was ok when I put the Nitron in a year ago, but after hearing your tale, who knows?PS. Not over torqued ?
The 10.9 designation is once again showing its Tensile strength, not its strength in shear which is the issue.
If the spring and damper unit is properly sprung and valved it will perform the function for which it was designed, absorbing the energy imparted to it by *Bumps* and turning it into heat that can be easily dissipated and in doing so preventing shock loadings. That's why they are known as 'Shock Absorbers'.If the spring rate is inadequate though the entire travel of the damper rod will be used up and at the very end of its travel the second line of defence, the bump-stop, a rubber collar around the damper rod will come into play acting as a cushion to prevent the piston or clevis on the other end of the rod simply whacking into the damper body and effectively turning the entire innit into a solid object acting like a bloody great drift that simply hammers on the mounting bolts at either end of the shock and imparts shear loadings on them.Unfortunately the bump stop can only work to a limited degree and for a limited time. If you look at shocks on most early Norges and Griso's in particular you'll find the bump stops are usually flogged to pieces by the constant bottoming out of the damper rods. The result is continual hammering on the mounting bolts which are designed to take a loading in tension, (Lengthways.) and not in shear, (Sideways.) something will, inevitably, give in the long term and in this case it is usually going to be the bolt!A spring is essentially *Battery* for kinetic energy. It stores it as it is extended or compressed from its at rest position and then releases it as it returns to that point. The energy is dissipated by forcing oil through valves within the damper body and turning the kinetic energy into heat. This prevents the spring from simply 'Pogoing' and speeds up and smooths out the dissipation of the unwanted and wasted energy. As a kid you may remember putting your thumb over the end of a bicycle tyre pump and pumping like crazy and finding that the end of the pump near your thumb getting really hot? Same principle. The air is acting as a spring and storing the energy of your frenzied pumping but not having any decent way to dissipate it it simply turns the energy imparted to the spring, (The air inside the pump tube.) into heat which it then imparts into the pump tube, piston and rod by conduction and hey-presto! The pump tube, (Most noticeably.) heats up!With the shock absorber, (And forks.) on your bike the extra energy just gets turned into heat and transferred by conduction from the oil within the shock to the shock body and then radiated. By putting a heavier spring on more energy can be stored in the spring meaning less has to be dissipated. If it can't store enough, (The spring is too soft.) then it will dissipate some of that energy by beating the ever-lovin' piss out of the mounting bolts! Or, in the case of forks, the steering head bearings.Pete
Chances are that the threads have no tension with the bolt head off. That means you might be able to use a screwdriver to catch some broken burr and turn it out. Also, a long left-handed drill bit might spin it out pretty easily. If you can get to the other end of the bolt you might be able to use a normal direction drill bit on it.
At the risk of..........If the bolt sheared, why would it not be likely to shear at the back of the bolt head or at the other end -inside surface of the nut , rather than in the middle (where the shear action would be less)Just askin
On the first break, you said.. but that time the bolt broke right where the threads started. Naturally, that is what you would expect.There's something I'm obviously not understanding here. That looks like a clean break right in the middle of the bolt. *Not* at any stress riser. <scratching head> I looked at the shop manual on line and didn't see anything about the shock mount. The parts list shows a bolt. Period. The sketch shows threads half way up or farther on the bolt.. but it just may be a sketch and have no resemblance to the real bolt. Is there a tapped mount on the frame where the bolt goes through the shock and bushing and just screws in? Maybe the bolt is bottoming in it and not letting the screw fully torque down the bushing? Curiouser and curiouser.
Oh it's strange all right but the fact it's happened twice would seem to indicate it's a causative failure rather than just a random and unlucky fault with material for example.I too would expect a failure to occur at the radius of the shank to the head of the bolt but since it hasn't failed there you need to expand the search for a cause. While I've seen several significantly bent top mounting bolts I've not seen a snapped one but in this case it's happened twice. The one obvious change is the custom built shock and to impose a bolt-snapping force on the mount the only thing I can see that might contribute is if the shock keeps bottoming out and the hammering is going to effect the bolt in shear.I may be completely wrong but it's the most logical explanation to me from half a world away......Pete
Is it possible for the OP to post a picture or 2 of the section view where it got broken off?but if I have to speculate, I suspect the bolt surface had been already been externally chipped or simply a "small deep dent".If it is so, the bolt can actually start cracking internally right at the tip of those dents (normally you can't see those crack because they are usually micro fractures starting within the body of the bolts) and until there are not enough area internally to withstand the force exerted by the shock...that will be when the bolt shears
I'll get the bolt cleaned up a bit and see if I can get a good photo or two of the end of the bolt.jdg
