Am I the only one who thinks two broken frame rails is a red flag?
No . As for how fast the OP is , well , I'm sorta having a hard time with this . 60 MPH over speed bumps on a '98 Cal , hmm ... Look , I'm not the fastest guy , but some of this sounds hyperbolic . Dusty
Brembo calipers are set up with shims between the caliper mount lugs and fork lugs. When you mount them you need to be sure the proper shims are in place, so the caliper is centered on the rotor.
My first thought on the frame rail is that it's being stressed abnormally. Either the frame is tweaked or the installation is incorrect. Is this model supposed to have that u-shaped strut underneath the transmission that connects the lower rails? I can't find a good picture. It was added because of flexing. If yours was supposed to have it and doesn't that could be significant.
I'd be going over the rail installation to find where the bind/stress/misalignment is. From your description of the break location I'd be suspicious of the length of the spacers and attendant stuff in the lower rear transmission mount/centerstand mount area. I'd also double-check the fit at the swingarm end of the rails.
Exhaust cracks are often due to stresses induced during installation, although cases of bad welds have been documented. I've been known to cut the crossover section and rejoin it using a few inches of flex pipe. This helps relax installations that just don't want to line up neatly.Your crossover crack might be associated with the frame rail cracks. The two are in the same general area, and the same types of forces would break them.
check wheel alignment with a straightedge? I've read that a long fluorescent bulb can be used...
To the person who asked -- Some Brembo stuff is rebuildable and some is not. Gold calipers are not. Most of their "modern" master cylinders are not. However, at last need, I was able to get P08 kits. To get around this supply issue, we might be able to use generic pistons and their matching seals. You can get the generic stuff by dimension, from various ebay sellers as well as some custom brake shops. I'm planning to try generic substitutions next time I need to rebuild one of those 32/30s.
How much time elapsed between the frame damage and the repair (s)? Any assitional stress placed on the damaged areas would be multiplied due to loss of integrity and could have led to deformation and mis-alignment in my book...
Forgive me if you did this. I gave up reading every post somewhere on the second page. You have done lots of stuff. Did you replace the fork springs themselves? John Henry
Tire pressure. Just cuz no one else is suggesting it, so I'll try a WAG...2.2 bar equals 32 psi. Try 38 psi, or 2.6 in the front.2.4 bar equals 34 psi. Try 42 psi, or 2.9 bar in the rear.Go ride for half an hour at your pace. Try to achieve a 10% rise from cold to warm tires. Less then 10% rise you've started with too much pressure. More than 10% means under inflated cold.An EV guy at Marcus Dairy was ready to sell his till we pumped up his tires. Whole new bike.But I'm also thinking of measuring the pins on the swingarm to see if they are equal out both sides of the frame
Steering head tightened to spec, loosened a bit (was too tight)
Brembo gold 4 pot rebuild kits available from these boys https://www.ebay.co.uk/itm/Moto-Guzzi-V11-Le-Mans-2001-2004-Brembo-front-brake-caliper-seal-repair-kit/181430373173?epid=1088520838&hash=item2a3e17cb35:g:Zf4AAOxymmJTkFJ6They have an impressive range of brembo stuff not available elsewhere
Are you sure this is still not too tight?
Steering head tightened to spec, loosened a bit (was too tight), checked again later. Swingarm aligned to the previous measurements, if there is a better way, let me know. I never checked the sidewalls, since they have no clue if it is going to me mounted on a light or heavy bike. Front fork oil... 10w agip. Forks aligned on the yokes.
Spokes loose ?
