... Using a timing light, check your work. If the full advance is off, rotate the complete points mounting plate to adjust.
A Fiat 127 might be right for one set of points but the other set is a mirror image. I don't recall which Fiat the other set came off of.
You mean rotate whole distributor body, do you not?
