Author Topic: Oil capacity  (Read 1224 times)
Offline Sykestone8886
Oil capacity
« on: August 01, 2019, 09:14:34 PM »
Could one of you guzzi gurus give me a little          Info ? I'm doing the service on my 2016 v7 stornello and for the life of me I cannot find my owners manual. I need the proper oil capacity for all three holes. Thanks !!'
Offline kballowe
  • - Kevin the Great -
Re: Oil capacity
« Reply #1 on: August 01, 2019, 09:19:52 PM »
Book says 2.0 liters but try 1.7 or so and check level.   They don't like to be even a little bit over the full mark.
Re: Oil capacity
« Reply #2 on: August 01, 2019, 09:40:57 PM »
Ok thanks. Do you happen to know off hand the tranny and the final drive ?
Re: Oil capacity
« Reply #3 on: August 01, 2019, 09:46:44 PM »
Offline kballowe
Re: Oil capacity
« Reply #4 on: August 01, 2019, 10:01:06 PM »
half a liter in the transmission
I fill the final drive until it starts to run out the inspection hole but I think the manual says 0.170 L
« Last Edit: August 01, 2019, 10:02:05 PM by kballowe »
Re: Oil capacity
« Reply #5 on: August 01, 2019, 10:08:20 PM »
Thanks for the help. I appreciate it.
Offline mechanicsavant
Re: Oil capacity
« Reply #6 on: August 02, 2019, 06:54:32 AM »
Also when doing the trans fluid don’t forget to pop out the screen/filter thingie & check it . Mine was metal free but had quite a bit of sealer in it
This was @ 6000 Mi. After the dealer did the initial 600 Mi. !
Re: Oil capacity
« Reply #7 on: August 02, 2019, 02:51:56 PM »
I made some notes
https://wildguzzi.com/forum/index.php?topic=100907.msg1596442#msg1596442
If you leave the filler plug in place while removing the drain plug the oil wont come gushing out, less mess that way.
Once you have it draining then you can remove the filler.
Half a V9 Roamer
Offline Vagrant
Re: Oil capacity
« Reply #8 on: August 03, 2019, 08:31:26 AM »
Ha! I bet he didn't pull it.
2016 V7II, 2017 V7-III Blue special, 2022 V85 the fast red one! 2016 650 Versys
Re: Oil capacity
« Reply #9 on: August 03, 2019, 05:45:57 PM »
Is the V7 1/2 a liter? I know the V7lll 6 speed is but the earlier V7's (5 speeds at least) still used the full liter I think.
edit: .19 in the diff, but who's counting. I did the correct amount once and found it was just starting to flow out of the rear plug, so now I don't even measure it; moly in first and then fill until it starts to flow.
« Last Edit: August 03, 2019, 05:48:20 PM by Muzz »
Online JoeKirby
Re: Oil capacity
« Reply #10 on: August 03, 2019, 05:53:44 PM »
If you are still looking for an owners manual or a service manual, visit Cadre Cycle's website
https://cadrecycle.com/moto-guzzi-owners-manuals/
My favorite rides:
1978 Triumph Bonneville
2005 Triumph Thruxton
2007 Triumph Sprint ST
2010 Moto Guzzi V7
2017 Moto Guzzi V9
Beechcraft BE24R
