I share your concerns Kfz but after 80,000 miles in mine it still worked well.Because I was flush I replaced it with this https://hmb-guzzi.de/Timing-Chain-tensioner-CNC-made-HMB-design but I don't really think it's going to make any real difference...just better made and a nicer (and more expensive-guzzi content ) design !
I found using a pair of needle nose vice grips to hold the tensioner against the side of the crankcase while reinstalling gears and chain is very useful.
The easiest way I found to install the bow type tensioner is to install the bracket first, then the chain and sprockets (as one assembly), and last slip the tensioner "shoe" onto the pivot stud. If necessary, I use a pair of needle-nose Vise-Grips to pull the spring out enough to slip onto the stud along with the "shoe".
Common sense Kev. The crank nut is a coarseish thread and the crank is nitride steel. The peg nut is something not a lot harder than mild steel. Essentially you do it up till you fart and if your 'Phf'Uffer valve is too strong the nut is the sacrificial part.The oil pump nur is an 8x1mm thread rather than the ISO standard 8x1.25, yes it will take more torque but in all honesty I think the 'Book' figure for 8x1.25 is probably excessive. Use the correct lock washer, (A simple split spring washer.) or a Schnoore and a drop of Loctite 243 and do it up until you feel you are coming up against the tolerance of elasticity. It's always worked for me......Pete
Its funny, how some mentioned that the quality of the "valtek" plastic looks a little questionable....Wha n I installed it in my cal II , it brought back memories of when I was a kid, in the 60's, my parents used to take me to amusement parks on the east coast, on the way down to Florida, such as Busch Gardens, etc, They always had machines, at the entrances where you would deposit a couple of coins, and it would mold you a dinosaur, or some other toy, from a type of thermo plastic, right in front of your eyes! It would drop out of the machine still hot, with a very unique smell. That reminded me of the valtek plastic! Any of you other old timers remember these?Rick.
I think my sister still has the mermaid we got on our trip to Cypress Gardens back in '72.. remember the burning hot plastic well!!!
These tensioners were first produced about 30 years ago as I recall ( I fitted one to my SP1000 around that time) so if they are still available there can't have been too many issues with them. Tony
