When putting this 98 EV gear box together for a friend he had a replacement speedo gear because the one in the 70K gear box was stripped, or worn over, when putting the new one in the cover it spins freely till you tighten the nut down, even finger tight, tighten with a wrench it will not move. The thought seems to be that the gear box cover was machined wrong. My friend who has worked on many many Guzzi transmissions has never seen this. It looks like I'll need to find a used EV gear box cover.
