under ~20k or so be very, very wary of an impending torque-converter pump-drive failure
Is there a general mileage guideline for the stock Convert pump drive? Are they prone to failure around 20k? 15k? 10k?
that was the early bikes. not cali IIs
I beg to differ, with all due respect to Mike's admittedly far greater knowledge of all things Guzzi than mine.
Here's the failed "hex piece" from my Convert: I was doing a bit of reading in Guzziology on the subject and the part about early vs. late couplers caught my eye. Early (which I obviously have in the bike right now) only engage the hex piece about 8 mm on that end. Late couplers engage the hex piece 11 mm - two of my spares are the late type. However, those two late type couplers still don't engage the hex piece very well rotationally - that is the hex piece rotates ~ 20 degrees before the coupler begins to move. That seems like a lot of "slop" to me and could be a factor in the hex piece rounding off. The hex piece was also a little sloppy in the camshaft, but not nearly like it is in the coupler. It seems like what I really need is a hex piece made to 6.1-6.2 mm vs. 6 mm. 1/4" (6.35 mm) is too large. A slightly oversized hex piece would get rid a nearly all of the slop, but would still allow for any possible misalignment between the coupler and camshaft. Along with the increased engagement length of the later coupler, I feel that it would make significant progress towards increased reliability.
So you are talking a ......240/.244 hex surface ground down from a .250" hex? That sounds doable. How long is it?
Yeah, could you just grind down a 1/4" hex to 6.2mm?
32 mm overall, but I really only need 12 mm ground down on one end and 10 on the other. I'll be talking to my machinist this week about doing it for me. Yes, that's my plan.
Wow thanks for all the info great stuff, I bought it yesterday pick it up in a week! Would love to find a stock seat and OEM windshield anyone holding?
WOW, that's clean! You scored a good one, and a good shop can alter the seat any way you like, but I might try 2-up riding just to see how comfy that seat is. If you're ACTUALLY going to tour on it, you'll be better off than the stock seat. Should be able to find a stock windshield with a little searching. I broke mine in a bonehead move with the garage door....still have the mounts, but went with a Califia fairing instead.Wish mine was that clean. Somebody took care of that beauty.
trust me you do not want the stock seat. give that one a try.
If it helps, here's a source for a seat cover:https://www.ebay.com/itm/Moto-Guzzi-California-Seat-Cover-New-Manufacture-GIVE-MODEL-DETAILS-WITH-ORDER/222300841710?hash=item33c229a6ee:g:zLUAAOSwZfNabb2z
:1:
Wonder why there's no dust wiper boots on the forks?
