https://jackson.craigslist.org/mcy/d/jackson-motoguzzi-2008-norge/7238291952.htmlNo connection to Seller...Steven Rossi
Labor is $1K, no need to pull motor. Front cover, pan & cyl's come off. Done a few.
Why did you need to remove the pan and cylinders ?
I've not worked on a Norge, but why do the cylinders have to come off?
If the oil pump failed what else happened inside the motor?
If I wanted a Norge, it would already be sitting in the Guzzi Garage. (tm)
I would offer half the money and take the bike away leaving it in his name.Take it home and do some diagnostics and if it fails, get your half back. If he refuses to refund your money, have another look at the internals... If he hands you back the half, you’ve lost nothing.If there’s a wire off the sender...? Happy days.I’ll take a bet with someone here that it’s not a rooted pump, especially on an ‘08... BTW..It wouldn’t hurt to ask the guy how he knows it’s the pump. His “mate” down the road on the front porch with the banjo, might have seen a flick of red once on the panel and wet his pants.Maybe it was the dreaded triangle and it’s nothing more than a shagged sender.Just buy the bastard, it’s cheap.
